backhoelover
I like tools
- 10:57 AM
- Feb 10, 2016
- lincolnton nc
you can give it to much fuel will smoke. way to much and gas will be coming out the muffler
Most WJ carb rebuild kits have a selection of pump diaphragms (not metering diaphragm).Comments would be appreciated. I believe the screen was omitted in the rebuild, and the lever may be a bit too high. The carb model looks like a Walbro J68B, but I can't find rebuild parts for that at all.
Would the slightly high lever and missing screen cause the saw to bog in the cut? Or is it more likely it ingested some dirt with the screen missing?
MS 660 Carb Help ... The carb was rebuilt by someone else, and the saw falls on it's face when you put it in the wood.
1 of those diaphragms has an extra hole in it 2 fit a different model carb.
If you fit the wrong diaphragm, the carburetor will flood itself continuously.
Just a thought without actually having it in hand to properly diagnose![]()
OEM or AM?
