What's on your bench?
5:34 PM
Not unusual. Heat from the muffler cooks it. It shrinks.....gets brittle....then gets gone.
Use some foil tape under the muffler.
Muffler volume must make a difference. Or you’d think they would’ve made it 1/8” smaller. Some of the used ones you can see where the muffler is actually wearing on top of the oil tank where it rubs
4:34 PM
Either that....or they are just *s-wordty engineers.
Ronie
5:34 PM
NC
Saved an 036 oil pump from the dumpster a few minutes ago, I broke the nipple off so I drilled it out and put a brass one in. If I just had a worm gear I could finish it up and see how it runs.
Kiwioilboiler
346 Pic Examiner
9:34 AM
Marsden Pt, NZ
Couple projects, ms440 muffler mod and a original set of 1997 371xp cases, probably use them to build the last xpw topend I have, I like that it's a first year set of cases.View attachment 323579 View attachment 323580
Timing! I just today split a pair of 365 cases. One 97, one 06. Think 97 was V1, 06 V4? Anyhoo, didn't think much of it at the time but internally the bar-stud area was definitely different. Was this one of the improvements touted as 371 became 372?
dustinwilt68
Wilt Built Work Saws
5:34 PM
Southwest PA
Yes sir, when they switched to the 372 they added reinforced area to the bar pad area, although honestly I have had several 371s and never had an issue.
Kiwioilboiler
346 Pic Examiner
9:34 AM
Marsden Pt, NZ
Alrighty then. Now its of possible interest i'll take some pics tomorrow and post em up.
Michpatriot
5:34 PM
Livonia Michigan
Today's cast iron welding..flywheels needed a 4140 ring to add inertia. Mixing another metal into the puddle making three materials including the rod keeps it interesting..Cast iron can be a bugger, but these went good. lots of preheat and then careful post weld heating..cover em up with a heat barrier and keep the fingers crossed.IMG_20220112_140122.jpg
