What's on your bench?
av8or3
12:18 AM
Waleska,Ga.
7E9C851F-C3B5-4D8B-9625-E0E97B33EF51.jpeg Here we go! 200 degrees internal temp. They should look like meteorites :).
And they do. I used a rub this time with a little heat. Can’t wait. We’ll wrap them up and set them in a cooler to rest awhile. Then we’ll pull em and have some lunch :aplastao:.
14 hours to cook these at about 220-230 degrees.
WillG
12:18 AM
Norwich CT
Did a little bit of Polish engineering to get the dishwasher at least useable. Took a garden hose repair end and put it on the end of the dishwasher drain hose and ran a garden hose to the sump.
Kiwioilboiler
346 Pic Examiner
4:18 PM
Marsden Pt, NZ
So can you now 'rod' the original drain line Will? I've used string trimmer line for a similar job in the past.
sledneck22
But, is the chain sharp?
11:18 PM
WI
View attachment 308605 Here we go! 200 degrees internal temp. They should look like meteorites :).
I did 16 lbs for pulled pork a couple months ago in my electric smoker.
It took 18 hours. In at 6am. Out at 12am. It was freekin delicious. I used a hot and spicy mustard for the rub paste and the bark was like a sweet heat. I had a sandwich that next more with my eggs. It was one of the best home cooked meals I’ve made.
Flip
12:18 AM
PIlot Mtn, NC
It's so nice outside, moved the bench to the picnic table under the pecan tree. Initial washing of 394, 555, & 242 cases before painting. The 555 & 242 will be build threads this winter. I think there are parts from 11 different saws going into them.
sledneck22
11:18 PM
WI
Drawer fronts have been completed today. Just sanding and finishing. Plus all the pieces there for the doors. Just need more time in the day.
stihl livin
Do the Dallas
11:18 PM
Upper Midwest
@WillG
Cut the copper pipe back to a flat area above and below the clog. Replace it with PVC and a rubber boot. And build a cleanout at the same time.
It's commonly done with cast iron pipe that is rotten.
look a little closer Jeff. Where the drain for the dishwasher is threaded into looks to be a threaded cap onto the copper. Maybe my eyes are not sitting right but I’d thread the cap off and install a larger elbow and reduce it on the vertical. Old plumbing elbows are not sweeping elbows like the pvc used today. I see lots of these older tight radius fittings plug up due to the sweep
Kiwioilboiler
346 Pic Examiner
4:18 PM
Marsden Pt, NZ
I know this is your jam Nic but surely a flexi rod into the elbow is a chance of clearing the blob as a primary fix?
Just looked again on PC. Are mac unions common in plumbing?
WillG
12:18 AM
Norwich CT
Thanks for the great idea. I'll suggest it to my dad. House was built in 1934 and who knows when the dishwasher was added. Yup the elbow is threaded into the cap.
RI Chevy
12:18 AM
earth
I hear you. So... PVC wouldn't be a good option? Should flow better with newer PVC...
stihl livin
Do the Dallas
11:18 PM
Upper Midwest
Adam you are correct but that elbow has such a short radius it will be difficult to get it to push through
WillG
12:18 AM
Norwich CT
Newest addition to my fleet. Runs excellent! Just need to get a bar and chain. Setting it up 14" 3/8 low profile.
12:18 AM
Those older echo tophandles/rear handle based tophandles are pretty bulletproof and simple. Not really fast cutters. But reliable and get the job done.
WillG
12:18 AM
Norwich CT
They're great little saws. Picking up the bar and chain tomorrow evening after work and then putting her to work cutting up the rest of a small tree that came down during Henri.
BlacknTan
12:18 AM
New York
Fooled with the 576 (xp) Auto Tune muffler before it gets shipped to the UP.
Still cutting my teeth on this process... don't know it it's helping or not, but I seem to perceive a difference. Maybe it's wishful thinking, but for now, this is the way I do 'em.
My buddy has a pulse TIG machine that works awesome on this thin steel.
