What's on your bench?
4:21 PM
That 066 I am working on frustrated me today!
Definitely want to pressure test it cause it has a AM cylinder that is burnt.
The first cylinder would not "seal" the spark plug, so I installed the BB cylinder, and it had leaks at both the spark plug and decomp. "Gorilla" tightening stopped them, but then the boot must have a pin hole! I will have to get a new boot and check it again, I'm hoping the seals are good as the bearings don't seem to have any play.
The only good news is (and I don't know what brand it is) the BB kit seems to have decent port work, and the squish with a gasket is .024, which s/b just fine.
The saw will get an OEM boot, piston pin bearing and decomp. Everything other than the P+C are OEM, but the case will need some repair where the upper dog bolt goes through. I was going to replace the case half, but now I'm thinking of gluing and pinning a washer to keep the bolt in the proper place.
The 460 case I glued back together (w/ PL Premium) about 2 yrs ago is still in service! It had been dropped out of a tree.
PA Dan
FYD
4:21 PM
White Oak PA
And your saving money how....?
WillG
4:21 PM
Norwich CT
Toro Timecutter Z4200 will be tomorrow after work. 19 hp Kohler Courage single. Getting an annual service, the deck put back on correctly, check and adjust the tracking and steering levers. Also getting a mulch kit.
Woodslasher
Teh debil
1:21 PM
Commiefornia
A few minor updates from the last few days. After months of it sitting disassembled I decided I was not going to paint my 1-43 so I put it back together for storage. Also, I fabbed up an adapter so I can run a good used Oregon D025 mount bar on my 2100/mill so I won't have to pull the D009 bar off of my 181 every time I want to use the mill. It isn't pretty, but it works!
