What's on your bench?
VinceGU05
one day when i grow up...
4:07 PM
S.E Australia
A bit of chain building and noting it's time for bed [emoji12]
Tor R
Novice, Leg model #2
10:07 PM
Mandal
My 133SG project....
Next time I'll be a bit more carefull, should be an easy fix since there was enough wire outside the heat element, thought I should not need to go so deep, used to much force and sat with the blue wire in my hand (the blue wire is attached 1 cm to the right, black dot spot)), this is how it look where the wiring is attached to heat elements...
Eventually it went okey....
I always thought Husky used slacker 543301 PTO bearings on 40/44/444/133 and so on.....surprised when I saw it was a special SKF bearing they used on 133. Never trust Huskies IPL's is my learning lesson
Onan18
OPE Sponsor
4:07 PM
Georgia
And the 346 is a runner, the 350 donated its starter, clutch cover, chain brake handle, tank, muffler with heat shields, and entire intake track. Starts easy and goes pretty well. Have her set at 13,200 right now, this is going to be Dads saw so all stock, even has a base gasket. Does have an unlimited coil though, I just couldn't help myself. ;)
Joe
calebng15
4:07 PM
Butte, MT
Couple things right now. First off is a br420c...blown top end.
Somebody gave it to a friend, not knowing why it wouldn't run. Wander why?!
Another buddy bought this saw for $25, and wanted me to get it running... blown top end!
