What's on your bench?
PA Dan
FYD
8:38 AM
White Oak PA
Stevetheboatguy
7:38 AM
Nw IL
A big pile of 025.......
Actually a good running little saw. But someone really cooked the clutch and melted the case through to the oil tank. Going to get tossed to the corner until a donor falls into my lap.
Steven
PA Dan
FYD
8:38 AM
White Oak PA
WillG
8:38 AM
Norwich CT
Foamed around the old stove pipe in the shop. Also filled the pipe with foam. A quality hack job.
Xr650jkallen
7:38 AM
Tennessee
I'm waiting on a new carb for it. The old one has too much aluminum rot and is giving me fits. The float pin pedestals are almost rotted in half.
RI Chevy
8:38 AM
earth
You could have used some owens corning fiberglass insulation inside too. Save the pipe. Not sure on that now though.
WillG
8:38 AM
Norwich CT
I was working with what I had on hand. No plans of having a wood stove in the garage again.
kingOFgEEEks
8:38 AM
Tioga County, PA
Don’t work on ton of husky and this will sound stupid but anyone have an easy way to get the limiters off the carb on a 372 Xp xtra torque? Bottom diaphragm got eaten from ethanol and I cleaned it best i could without pulling jets. It will run but is lean on bottom end so something is slightly plugged or the metering lever needs a tweak. So if i need to buy the tool to pull limiters so be it. This one looks like a metal limiter cap so far all the other husky had plastic like a Stihl. I’ll take the metering lever hight spec also if anyone has it.
If it's the type I think you're talking about, you can bypass them in-place with the splined carb adjusting tool:
Or you can remove the whole thing by pushing down on the limiter with one small screwdriver or pick, then unscrewing the needle. the limiter collar can be trimmed off. I had the same question a couple years ago:
https://opeforum.com/threads/defeating-limiters-on-walbro-carb-2188-390.9462/
