What's on your bench?
Ronie
8:39 AM
NC
nbbt
7:39 AM
5543X, 5644X
lehman live edge slab
Live Action
7:39 AM
Mn
Watch the HL Supply sales, you can get a oem 346 p&c for around $100 sometimes.
Also I have tried the 2149/351, 2152/353 and the 2153/346 top ends and in my opinion the 346 top end is worth the money. The 351/2149 top end is second best in my opinion.
Or I'll trade you the j-red for a project 034 super.......maybe anyway
That may be a possibility depending on what kind of project yours is, this one is real nice shape and looking at the bar I have a pretty good idea why it roached. I’m thinking new piston and cylinder will be it maybe a set of crank seals bearings a smooth and tight.
Johnmn
7:39 AM
Minnesota
I'll pm you a little later
bigbadbob
5:39 AM
Interior BC Canada
Got a 046 for some work on a 661.
046 got new bearings, seals, slug, was a loggers saw so its been around the block, lil ugly
He doesnt do any of his own work,
I found the timing advanced, and that seems to be it,, rest looks stock,
I did MM BG .
No pics,, ya all see a 046 B4
The case gasket that came from stihl was the wrong one in the rite bag,, had to wait for another one.
WillG
8:39 AM
Norwich CT
Yamaha golf cart. Carb rebuilt, new choke cable and nut, new CV belt. Tomorrow I just need to toss a new plug in it, replace the fuel filter and change the oil. Also going to clean up the battery and battery terminals and install a positive terminal cover. May or may not have taken it for a joyride in the snow. Gotta make sure it runs good....
nbbt
7:39 AM
5543X, 5644X
Did you mount yours on a pad or cushion ?
I mounted on a 30 x 30 pallet to get off the floor a small amount, Placed cushion floor mats sections (type you would usually use for fatigue mats) between the floor and pallet, this stopped it walking around and dampened the vibration most of the way.
WillG
8:39 AM
Norwich CT
Finished up the Yamaha golf cart. New plug, fuel filter, oil change and cleaned/protected the battery terminals. Took it for a toot up the road to make sure it's good to go, which it is. It was a very cold test ride too!!
Exmark Commercial 30 and Craftsman snowblower both dropped off for get running/service.
Live Action
7:39 AM
Mn
Don’t work on ton of husky and this will sound stupid but anyone have an easy way to get the limiters off the carb on a 372 Xp xtra torque? Bottom diaphragm got eaten from ethanol and I cleaned it best i could without pulling jets. It will run but is lean on bottom end so something is slightly plugged or the metering lever needs a tweak. So if i need to buy the tool to pull limiters so be it. This one looks like a metal limiter cap so far all the other husky had plastic like a Stihl. I’ll take the metering lever hight spec also if anyone has it.
WillG
8:39 AM
Norwich CT
Installation finished. Also installed a Talon shallow water anchor. Pretty cool boat too. The Torqueedo is equivalent to an 8 hp gasoline outboard. It's 48v DC. The lake where he uses it doesn't allow gasoline engines.
