Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:27 PM
Provencal, Louisiana
As it pertains to the bottom end. Are you talking about residual oil?
Yes. Shutdown under wot in cut when planning on checking. I know it takes radioactive testing to measure the amount and all that but its a visible difference and very apparent less wear on the piston skirts and cylinder using super and kl200 compared to all the other oils Ive used
CR500
12:27 AM
Western NY
I got a nib 441 crank laying around somewhere
The dolmar is next on the list to port!!!
Once ported and the grieving process is over
I will rebuild!!!! Just not immediately, have to see how much parts will cost including discount
bwalker
12:27 AM
Montana
Yes. Shutdown under wot in cut when planning on checking. I know it takes radioactive testing to measure the amount and all that but its a visible difference and very apparent less wear on the piston skirts and cylinder using super and kl200 compared to all the other oils ive used
Residual oil is a product of ratio and how the motor was operates prior to shutdown. Oil brand really doesn't have much of any influence on this.
The other parameter your using is totaly subjective in nature.
Keith Gandy
11:27 PM
I agree but I know what Ive seen with my own eyes over and over in alot of different equipment but im stickin with what Ive seen. Ill disagree on the ratio being the factor on residual though as I have no doubt seen how the Klotz migrates at even 42to1 compared to other oils at 32to1. There is no doubt something different about the Klotz
bwalker
12:27 AM
Montana
You can disagree all you want, but you are not correct and Maxima test that you alluded to earlier proves this. X amount of oil going in a motor= the amount of oil left in the crank case at shut down.
jmssaws
Banneded
11:27 PM
I have never taken a saw apart that was ran on stihl oil at 50:1 that had any oil anywhere,there dry as a bone so I don't agree with it either.
I run klotz at 50:1 and everything is covered in oil.
Why the difference if brand of oil makes no difference
stihl saws
You can always justify another saw.
12:27 AM
Virginia
The 660 I just took apart was ran on Stihl at 50:1. It hadn't been ran in about 2 months since I blocked up and noodled some big pine. It still had a solid film of oil on everything.
Keith Gandy
11:27 PM
I got mad respect for your knowledge here but I will disagree and continue to use kl200 until I see evidence that proves otherwise
paragonbuilder
12:27 AM
Norwich, CT
I've tried it with 190 lbs of compression and it wasn't much. I did milling cuts 3' or 4' long 12" wide. 87 was fastest. VP 94 was 2nd. 90 marine was 3rd and 93 pump was slowest. Next will be e85 or methanol if I can find a gallon of it.
I've got plenty of methanol if your ever out my way. I'm not sure about shipping it? Is it legal to ship? I'm not sure but dry gas may be pure methanol as well.
Keith Gandy
11:27 PM
No sense in tryin to debate with Ben Jason. Im not sure if u read any of the oil thread on AS but he made fools with all of us!! Lol! I still know what Ive seen and no doubt works for me and have 0 intentions to change
