- 1:26 PM
- Dec 30, 2015
- Brewster, NY
I believe straight 30 weight oil is what they used to use, but now that we have Ethanol ...
There is only one way to find outI never got an answer. Can I get away with running used Mobil 1 engine oil at 40:1, or should I go heavier?
Be a man and run 200:1, the environment will thank You.I've been thinking. It's synthetic so...
100:1 it is!
Blue oil is better with red oil mixed together so you get purple. Don't you know anything?![]()
You can skip all that added stuff with bio in your tank. Now it finally cooled off you can stop worrying about bio-growth in the tank and fuel system till springtime arrives.I used to add the cheap walmart TC3 stuff. But now I run biodiesel. Much better lubricant for the injectors. [emoji106]
I run diesel fuel additive in every tank of fuel since new...
Either Stanadyne, Power Service, or Howes etc..
I've never used VP race fuel don't know anything about it.You can skip all that added stuff with bio in your tank. Now it finally cooled off you can stop worrying about bio-growth in the tank and fuel system till springtime arrives.
I just switched back to the cheap Supertec tcw3 oil because it burns so good in my two-cycle motors like the weed whip, the leaf blower and my saws, all the saws. I am running VP full synthetic in my mix @25%. So far so good. The mix goes in the fuel can at the same time and run off with pump 89E10 or 90-91E10. The burn is clean and I feel that enough synthetic reaches the bearings to lube them well. The proof will be, did I stop the piston skirt wear? Time will tell when the jugs get pulled in the spring to measure the skirt wear. This will be my second year to test a custom mix of my choosing. Ymmv
But I'm pretty sure I read somewhere within the last month they have had a civil lawsuit taken against them for fraud? there fuel containing nothing the label says it does same as octane being nothing like clamed. From memory the owner boss or ceo? thought there was big money to be made cutting corners leaving out all the good stuff that is expensive and selling cheap crap fuel for big profits.
And you guys in the USA know anything more on this ?
Yeah I'll Google it to confirm what the go is.
Never used it. It says FD certified so i’d say it was as good as anything else that is certified.Anyone ever try this?
I'm just about out of my VP stash and was wondering if anyone has any input
