jake wells
no longer here
7:00 AM
ky
You can get a lot of carbon deposits in a 4 cycle also not just 2 cycles and plus i find any 2 stroke ran with klotz looks better than 4 cycle running stardard pump gas.
and there are oils out there that are 10x dirtier burning than klotz its called stihl oil.
here is a 4 cyl 4 cycle fuel injected engine for comparison.
Redbull661
661 hoarder (BlueBallz)
7:00 AM
MN
after about 1.5 gallons of gas mixed with Mobil 1 2t racing (red colored) 32:1
this muffler has been used on other 661s I have so the inside really can't show. But the cover was pretty clean.
spark plug
Jug - the brown is not build up, it's oil that can be wiped away. The jug is very very clean.
Tree Monkey photo bombing my picture!
Piston and crank - plenty of oil on the skirts. Good coating on the crank etc. Clean. Oil puddling inside those trox heads.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
7:00 AM
Provencal, Louisiana
View attachment 17854 View attachment 17854
Wow!! That should clear things up alil on carbon discussions
Crzybowhntr
Apprentice Slacker
8:00 AM
WV
Could running 2r @ 32:1 through my fs130 r be causing it not to idle very long? I don't recall that issue when I was running it on 40:1 husky xp oil.
Curious to know if more oil causes that type of issue
jmssaws
Banneded
7:00 AM
I just put a new piston in my 064, how long should it take to get a decent wash?
8:00 AM
With some oils I can see a nice wash in half a tank. Mobil and Dumonde are easy to see. They wipe right off as well but there's carbon on there quick.
Ron660
7:00 AM
NW Louisiana
spark plug
Tune looks good.
Ron660
7:00 AM
NW Louisiana
It is cleaner than super or 927 in a firewood saw. Cleanest is my lowest priority for picking oil. Fastest and happiest saw are top.
I'm curious to see the "timed cuts" from Redbull's oil tests. Proper lubrication in the lower-end is probably the most important criteria no matter what brand of oil you're using.
Ron660
7:00 AM
NW Louisiana
Never had any problems from gas and oil. I don't keep track of how long a saw last but I'd say 2 or 3 years if it's taken care of.
If you're not experiencing any engine malfunctions due to the type and quantity of oil you're using, I'd say it's a good oil. No matter what the piston crown looks like.
