junkman
Crush it
5:08 PM
pacific northwest
Ever check your tune milling? Just curious if you tune richer when milling compared to cutting firewood?
Same tune as cutting .maybe slightly richer 13k or so on 660 ,in the pass it is pretty smooth between 8-9000 rmps
Square full skip?
i run full comp and full skip ,if w want a little nicer finish will use full comp ,full skip leaves a decent finish also ,just not as nice as full comp ,full skip is a little faster ripping though ,clears the chips better .
Moparmyway
Its just a saw
8:08 PM
In a meeting
My 660 likes 24:1 in the summer cutting stumps with the bar oiler turned up.
Yuppers, thats what muh stumpers eat year round when they b stumpin !!
24:1 ain't just for the summer.........
Stihl 201t Stihl Ultra @ 50to1. Bearings r shot and slide on/off by hand and crank was moving side to side in crankcase. Ring lands were full of carbon
Yuck !!
Stihl working Hard
Is it Friday yet
8:08 AM
Perth Australia
Keith Gandy
Maxima K2 40:1 87 Pump Gas
7:08 PM
Provencal, Louisiana
That's terrible Keith the only oil I buy from Stihl is biodegradable bar oil it's Mobil1 Racing 2T in the fuel for me @ 40:1 zip carbon;)
Im not sure whats goin on with this saw unless its tuned too lean. Generally the Stihl Ultra thats in equipment that I work on looks pretty clean in the ring lands and some doesnt. These rings were getting tight20170716_065523.jpg
Stihl working Hard
Is it Friday yet
8:08 AM
Perth Australia
Im not sure whats goin on with this saw unless its tuned too lean. Generally the Stihl Ultra thats in equipment that I work on looks pretty clean in the ring lands and some doesnt. These rings were getting tightView attachment 78595
Tried it once Keith but it burns my eyes something bad ,I know a treelopper using ultra and have rings sticking as well
Ron660
7:08 PM
NW Louisiana
Maybe they'll switch to a better oil after that diagnosis.
rogue60
10:08 AM
AU
Now fellers yall know if I was runnin any oil other than RA she woulda cried WOLF!!!!:campeon::eek::eek::D
I don't know about that I've run saws for a few days at a time not a few minutes with big air leaks ripped intake boots leaking crank seals on Cheap Castrol mineral oil at 25:1 with no ill effects wear or failure to the power head but then they are Stihls lol...the work needs doing the saw still runs so ya just keep at it...
Keith Gandy
7:08 PM
Not common practice for me brother!:eek::D Id pick up another saw if I had one until I could fix the problem instead of running a known problem if I was aware of it? Ive seen saws drop cylinder/piston in a few minutes with air leaks
rogue60
10:08 AM
AU
Not a problem for me to keep running a saw with known air leak thanks to running the same oil and 25:1 mix for over 20 years I have never had a failure due to an air leak I have confidence in the oil to keep running the saw, I've done lots of testing this oil but I just call it work...
Keith Gandy
7:08 PM
Sounds good brother:)
