bwalker
4:34 PM
Montana
So Original would be your pick out of the Klotz lineup?
R50 at 32:1 still is excessive IMO lol.
Will mix up some original at 32:1 this weekend. Only ran it at 50:1 and it looked a tich dry....however Ben, residual is a heavily influenced factor from many things.
Ran Benol at 32:1 with the leaner coil on the 661 while running the maxflow and everything was decent looking. Castor does burn dirty I know but it is arguable that it does lubricate better than some synthetics.
There is a trade off with Benol and I understand this, I run synthetics this time of year due to weather lol
Will run original at 32:1 year round if I really like it.
Still will not be afraid of2r at 32:1 lol. K2 or Super M at that ratio have not cooked a saw yet either.
I broke in a 562 on2R and Super M. Saw never missed a beat or had any abnormal wear.
Sent from my non internal combustion device.
I don't know anything about OT as I have never used and and don't have the desire too.
People here say it's decent, but I take that with a huge grain of salt given they seem to cheerleader for one oil one weak and another the next. Never really running one particular oil long enough to tell squat.
bwalker
4:34 PM
Montana
Here is what i wanna see done to convince me of a good ratio.
Make three cuts in a 22 in inch log with moderate pressure at 6 second intervals on a 78 degree day in may on 47:1
Then after those cuts i want you to count to 12 grab your nuts and take 6 steps backwards then approach the saw right foot forward.
After that procedure i want you to count to 57 and start to take the saw apart and take pictures of the residual oil and report back.
Can someone do that for me please..then i will know if 47:1 is good for my chainsaw...thanks.
Anymore I would rather let the chainsaw wear itself out than tear one down.
After all saws are cheap, disposable equipment that is constantly being improved technology wise.
sawmikaze
4:34 PM
steeltown
Correct.
I know you guys are into this stuff and i can appreciate it.. but...
So many things are gonna go wrong with a saw that actually gets worked long before oil is an issue.
Fun to read all this though..lol
4:34 PM
I ran about a whole case of the stuff back before people got too carries away on the oil thing with having a super clean piston top. I started using it in 2009 or so after all the race saw guys were using it. The picture I posted of the piston last was benol and it was one tank and part of another one. A lot of soot for no more fuel than that on a new piston. Saw was only tuned to 13.4k at the time.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
3:34 PM
Provencal, Louisiana
One of the reasons I use kl200 is that testimony u gave me. I disagree with Ben in that u have to wear a saw out to tell what an oil is doing. Sometimes a few tanks will indicate what that oil will produce in extended lengths. Heck I partially stuck a ring with Supertechniplate in less than 3 tanks in a 550xp
4:34 PM
Cut4fun has used it for 10 years. If it was good enough for the hotsaws it's plenty good for firewood saws. Plus the tuning isn't weird.
KenJax Tree
¯\_(ツ)_/¯
4:34 PM
Over there
Lol.
I only take saws apart when there is something wrong with them...but i could take pictures of saws ran on *s-wordty dino oil with 87oct gas with who knows how much ethanol mixed with sawdust/snow and elephant nuts in the tank along with a choked up muffler that barely breathes that have clear cut hundreds of acres of logs with little maintenance..if any at all ?
Does that count ?
Ill keep makin 40 because i dont have to use my ratio rite now with the bottles i have and id rather have more oil for the rare moments i need a big saw with a big bar for long cuts...but to say 50 doesnt work is impossible for me to believe , the abuse ive seen these tools take is unreal and they keep workin..let alone for a polisher who runs a retarded sharp chain with a spotless air filter and ethanol free gas along with a good muffler mod to get some heat out , a saw is gonna last a LONG time at 50 with a quality synthetic oil and a mindful operator.
Don't forget to check the thermocouple attached to the bar for temps in between cuts.
sawmikaze
4:34 PM
steeltown
Im bein dead serious with this question keith..no disrespect.
Why in the hell did you run ST in a chainsaw ?
I bet it wouldnt have happened with your red armor.
Keith Gandy
3:34 PM
Here is Red Armor again since I tore this 064 hybrid back down to get the lightened piston out of my firewood saw before it blows up!! I lightened the piston from 96g to 80 and that may be ok but I dont trust it20161116_062555.jpg
Keith Gandy
3:34 PM
Im gonna give your beloved red armor a spin when it gets here...what am i supposed to notice or look for over using saber ?
Nothing really. It keeps a engine clean and its RED!!!:D. I think for performance and timed cuts Id run kl200 but thats a guess and not tested. I like the OPE oil for everyday use and the corrosion protection
