Redbull661
661 hoarder (BlueBallz)
- 12:24 AM
- Dec 31, 2015
- MN
You need a cordless probeStill figuring this out. ...any suggestions welcomed
You might try diluting it with some gasoline.After two gallons of Benol.View attachment 37306
Yeah I figured so.40:1
The machine calls for 32:1. I had some of the benol mix leftover from a dirt bike I needed to get rid of or I wouldnt have ran it. Wasn't a mystery what happened.Yeah I figured so.
I have no idea. Never ran benol or a dirt bikeThe machine calls for 32:1. I had some of the benol mix leftover from a dirt bike I needed to get rid of or I wouldnt have ran it. Wasn't a mystery what happened.
I'm not sure I understand that theory. Could you explain a little I thought more oil would give more protection? I'd guess with more oil the machine wouldn't be able to burn more oil than it didn't at 40-1I bet at 32 to 1 it would have spooged less ,would have leaned it out some .
By adding more oil, it thickens the fuel mixture, allowing less mixture to flow through the jets, effectively leaning the air-fuel mixture. It only really works with non-adjustable jets, otherwise, you'd just turn the jet in to lean it outI'm not sure I understand that theory. Could you explain a little I thought more oil would give more protection? I'd guess with more oil the machine wouldn't be able to burn more oil than it didn't at 40-1
32 to 1 is leaner than 40 to 1 so will burn leaner with same jets .I'm not sure I understand that theory. Could you explain a little I thought more oil would give more protection? I'd guess with more oil the machine wouldn't be able to burn more oil than it didn't at 40-1
I would've assumed the extra oil though ever so slightly thicker would've slipped right on through with the same volume or such minimal difference the extra oil would make it richer. Common misconception?
At 32to1 u r trying to shove more oil molecules through a given orfice than at 40to1. Think choke pointI would've assumed the extra oil though ever so slightly thicker would've slipped right on through with the same volume or such minimal difference the extra oil would make it richer. Common misconception?
