pbillyi69
5:37 AM
USA
clipper lube is a great idea. that is exactly what im going to use the rest of mine for
slackinoff
7:37 AM
usa
He's worried about having a special mix for one saw and forgetting to use that blend. I'm of the mind the while fleet should be hp2, dominator, or h1r at 40:1. Stock or ported.
HP2 at 40:1 is what everything runs here. Even my 4 stroke string trimmer runs it....and it's not the stihl that actually needs pre mix, it's a husky 324L 4 stroke trimmer with oil in the crankcase. Been running it on 40:1 for 4 years now. Great trimmer btw, sounds like a little motocross bike and it revs up just as fast as a MX bike too.
NateSaw
8:37 AM
Maryland, USA
After what I saw at and learned at the gtg, red armor too. All I run is hp2 up till now. My lawn mower gets it lol. Rather foul a plug than have a straight gas can laying around.
Loony661
462’s 4-LIFE
7:37 AM
Winona County, MN
FWIW, I’ve never fouled a plug in any of my saws - many of my saws have run the same plug for years. I have changed them out of spite before, but I have also seen a couple fouled on other peoples/customer saws that I’ve worked on. After working in a saw shop for 11 years, I can say IME’s that fouled plugs are few and far between on chainsaws - you really gotta try to get them that dirty.
NateSaw
8:37 AM
Maryland, USA
I was referring to my lawn mower lol. However, I haven't even fouled that yet with mix fuel.
NateSaw
8:37 AM
Maryland, USA
There was an OPE shop here that sent every new piece of equipment out the door with Opti2 at 70:1; including lawn mowers, zero turns, generators, etc
I'm becoming a believer! I mean why not lube everything. It's gotta be better for the valve seats etc. Valve guides, probably the seals too. I mean the crank seals on these saws and such hold up longer than they seemingly should.
karrl
8:37 AM
Sussex County, NJ
Is Opti 2 any good? I remember seeing packets of it whenever I went to the lawnmower shop as a kid. They still sell it but I never seen anyone run it.
karrl
8:37 AM
Sussex County, NJ
I agree, I dump any old mix into the my old Honda splitter motor. Doesn’t smoke so I doubt it’s leaving much behind.
Hinerman
7:37 AM
NE OK
Not sure. Some people swear by it. I have never heard anything bad about it, but I don’t know anybody that uses it
Hinerman
7:37 AM
NE OK
It’s probably fine. Sounds like a cult, but I run Red Armor so I’m all set on kool aid.
Opti2 has been discussed in this thread, not very much though. I think it is a quality oil, like most of the oils discussed on here. I would not hesitate to use it, but not at the recommended ratio. Here is a post from the past.
2:37 PM
I must have mixed mineral 4-stroke engine oil at ratios beyond 25:1 in my early years of chainsaw use.
All I remember, if I wasn't surounded in a white cloud of smoke I'd ad more oil directly into the fuel tank.
Those saws of old didn't seem to mind, on the contrary.
I ran my dads Sachs-Dolmar 105.
I had no clue what I was doing regarding chain sharpening, cutting techniques, nor maintenance - as long as the engine ran and the chain spun I called it good.
mrxlh
I stayed late and finished!
7:37 AM
Dat Boot
It was lean tested and did alright.
