- 7:09 AM
- Dec 3, 2015
- Banner Springs Tennessee
Pistons seal against the bore because the charge gets behind the ring and pushes it against the bore
However Asians of carbon can break away and get stuck between the piston , the piston ring and the bore gouging the surface .
Build ups like that are either too much oil or labouring the the engine so throttle is wide open but engine is running well below full speed .
Or some times both .
Agreed.
