- 2:43 PM
- Dec 3, 2015
- Banner Springs Tennessee
Which is why I recently became an Amsoil dealer.Lucas products are waaaayyy overpriced for what they are.
Common sense. That's that ticket. Sadly, common sense ain't so common these days.Randy, I have seen the large rod bearing fail on 2 Asian big bore saws running Stihl oil at 50:1. Had the owner switch to Amsoil at 40:1 and his third saw has far outlasted the other two.
Also, (correct me if I'm wrong), but I believe you generally recommend a good oil at 40:1 in all your ported saws, which should reduce oil failures.
My take:
1) I believe Asian saws, in general, are not as tough as OEM and need additional protection.
2) Big bores (heavier pistons) and porting put more stress on a saw.
3) If my oil mix works for Asian saws, my OEM saws should last for a long, long time!
I don't claim to be an expert, but I do try to learn from observation and use common sense.
Bingo.Thank you for this post. I've tried to make this point in several oil threads and been ridiculed for it. If the saws aren't failing, the oil is doing its job despite what appearances may lead people to believe. Some oils may be better than others for one person's personal preferences, but that doesn't make the other oils crap. The vast majority of the time they work. If they didn't you'd have forums full of people talking about their bottom end failures, the class action lawsuits, the recalls... But none of that happens. Because the oils work when used correctly.
Unfortunately the zealots won't accept reason and actual outcomes as any kind of evidence. So the oil threads continue...
