- 7:25 PM
- Feb 23, 2023
- Montana
Makes sense. I have also read it wad more to do with manufacturers trying to meet emissions. Either way. It's still because of emissions/trying to run cleaner.50:1 was pretty much a government EPA emissions implementation, nothing more really.
There’s a lot of information out there regarding mix ratios, but it was proven in dirt bike engine testing that 24:1 yielded the most power. After the testing, it was determined that the greater amount of oil provided better ring sealing and higher compression, with less blow-by.
That also makes sense. I wonder what the difference would be in double ring vs single ring setup.
O for a dyno to test with.
Dry cylinder walls don't build compression good. I was looking at a Evinrude v4 115 years ago that they guy said had low compression. It also had sat for alot of years. I asked him to dump some oil in and crank it without the plugs for a bit then check compression again, it went from 50 to 60 psi to 120s or 140s (can't remember exactly ) Needless to say I bought it and it started and ran good.
