jake wells
no longer here
1:34 PM
ky
work like any other i suppose go on ebay and order a bottle to try.
Cut4fun
Redneck Chainsaw Repair
2:34 PM
Ohio
Ben have you ever had experience with Klotz KL198 lite?
Been out since 2003 or around there. Folks say it is like 5wt oil thin wise.
I bet that 661 was all over the place with carb trying to tune with those washers in the intake.
No oil related problems I see there.
Lot of grit of some kind but from where?
CR500
2:34 PM
Western NY
Do all these intake boots fail or some?
Mine appears to act normal even with the older coil
Sent from my non internal combustion device.
bwalker
2:34 PM
Montana
Fwiw Klotz R-50 is a 50wt oil.
jmssaws
Banneded
1:34 PM
I put the new coil on it and it didn't run as good. Your boot doesn't have anything in it.
skidooguy
Genuine smartass
12:34 PM
Wyoming
image.jpeg75 cents a quart at my local coop. Might have to test it out on the Poulan one of these days.
Cut4fun
2:34 PM
Ohio
I was not talking about R-50, I was talking about KL-198 being 5wt from end users reports ;)
Never used either of the above here.
It is suppose to be a lite, original.
bwalker
2:34 PM
Montana
I realise that..I posted that for comparison sake.
Cut4fun
2:34 PM
Ohio
Share something I read last year. Just for chits and reading of those bored oil driven folks.
Wow there is a charter limiter on here. Guess I will try to break down to 4 parts.
The late Great Oil Debate
By Robert Verret
Apr 2015
There are very few subjects that stir the emotions of PWC performance enthusiasts more than to ask, what 2 stroke oil do you use and why? This site has dedicated more ‘bandwidth’ to this subject than just about any other topic. Most of the discussions end up in heated debate with no one really changing anyone else’s mind on what oil is the best anyway. We tend to vehemently defend our choice as if our very reputation depended on it. I sometimes think we are more loyal to our favorite brands of oil than to our favorite brand of ski (hopefully Sea-Doo). Well, maybe we’re not quite that loyal to our oils, but close to it. If it’s any consolation, PWC performance enthusiasts are not the only group of “motorheads” that staunchly defends their choice of oil. I belong to several other performance oriented motorsport discussion groups (Ford-Diesel and Racetech-KTM) and they do it also. With all this said, let’s all take a deep breath and put our emotions and biases in a closet somewhere and try to look at this magic miracle ‘brew’ we call 2-stroke engine oil.
What’s in the stuff anyway?
2-stroke engine oils, like most other engine and gear lubricants, are composed of base oil plus an additive package. The additive package can be as simple (only one or two components) or as complex (multiple components), depending on the requirements of the oil.
Base Oil Types
Base oils compose from 50% to 95% of the total weight of the 2-stroke engine oil. They fall into 2 general categories: synthetic and petroleum based. There is a third category, vegetable, I will discuss later. Since synthetic oils are manufactured from petroleum, there has been a lot of litigation flying around about what really constitutes a ‘true synthetic’ oil in the last several years. There is no universally accepted definition for synthetic oil. Each manufacturer is free to label their product ‘synthetic’ by whatever rules the manufacturer chooses. The API (American Petroleum Institute) has defined base oils into 5 different grades or groups rather than use the terms synthetic and conventional (petroleum). The groups are classified by quality of their VI (viscosity index). The VI is a relative measure of the base oil’s ability to not thicken at low temperatures and not thin out at high temperatures. The higher the VI number, the more resistant the oil to changes in viscosity as its temperature changes. Perfect base oil would have no viscosity change at all with temperature change. Some silicone-based oils have extremely high VI, but, unfortunately, they are terrible metal lubricants, so they can’t be considered for engine lubrication. The higher the API group number, the higher the VI number. Most, if not all, high performance 2-stroke oils are manufactured using API group III and IV and occasionally group V base oils. GroupIII (hydrocracked/hydro-treated petroleum oils) are used in non-synthetic and synthetic blends and Group IV (VHVI and PAO synthetic oils) are used in full synthetic and synthetic blends. Group V (Ester synthetic base oils) is rarely used because of their expense and they do not mix easily with gasoline and they are not compatible with some other oils. There are a number of advantages to using synthetic base oil in addition to the better VI. Synthetics have a much higher flash point than petroleum base oils.
Synthetics will not decompose as easily at high engine temperatures as petroleum. The engine stays cleaner because less varnish deposits on the power valves, ring lands and piston crown. They also transfer heat better than petroleum-based oils. In summary, it’s fair to say synthetic based oils (with the correct additive package) will out perform their petroleum-based cousins at extreme loads/temperatures. I mentioned a third category of base oils earlier, vegetable or Castor (not Castrol, that’s a manufacturer) bean oil. This oil is derived from pressing oil out of castor beans and distilling it. ‘Bean Oil’ as it is often referred to, has some very unique characteristics; some very good, others not so good. The good is that it is an excellent lubricant. It seeks out hot spots in the engine and clings to those hot surfaces much better than petroleum type oils. The bad is that it does not mix with gasoline easily and it burns ‘dirty’ (excessive carbon/varnish deposits). In the early 70s, before power valves were used, castor bean oil was very popular in racing 2-strokes. Now that power valves are common and we have improved petroleum and synthetic oils, castor bean oil is seldom used anymore. Several companies still market it in the form of a degummed castor oil for racing applications only. It should be avoided for recreational use unless you enjoy tearing your engine down for a top end cleanup fairly often. Several manufacturers formulate their oil with castor bean oil as an additive (antiwear agent) rather than base oil. They blend it with their petroleum and synthetic base oils. When castor bean oil burns, it has an unmistakable ‘sweet’ smell.
Cut4fun
2:34 PM
Ohio
part 2
Additives
If science could develop a base oil that would not thermally decompose (burn) until 1600 deg/f and not change in viscosity for –40 to 600 deg/f and not pollute the water or air, we would not need any additives in the base oil. Wouldn’t it be nice if all the oil collected in the expansion chamber body stayed in the same pristine state it went into the engine? We could simply recycle it. Well this isn’t going to happen in our lifetime (sorry, not even you younger guys will ever see this). Lubrication science is just not there yet. Additives are combined with the base oil to fix certain faults with the base oil or stretch the limits of the base oil in some cases. Additives are complex chemicals that account for most of the cost of a bottle of 2-stroke oil. Additives for 2-stroke oils fall into several general categories: Detergent/Dispersants, Antiwear agents, Biodegradability components, and antioxidants. Since the lubricating oil must burn as part of the combustion process in a 2-stroke engine, the residue resulting from this combustion process must be swept away after each firing stroke. If not, the residue (varnish, lacquer and other heavy hydrocarbon compounds) would build up and plug the exhaust port and stick the rings and power valve(s). Detergents/dispersants must be added to the oil to prevent this problem. The two types of detergents/dispersants most commonly used in 2-stoke oil formations are Ashless and Low Ash. Medium Ash and High Ash detergents are not used in 2-stoke oils. Ashless detergents are used in low temperature applications such as TCW3 oils where the ring land temperature is held below 300 deg/f. These detergents work well in engines where an excess of cooling capacity is available and power valves are not used. Ashless detergents are manufactured form organic nitrogen compounds (Hydrazine) instead of heavy metal compounds; therefore, they produce no ash as they are burned away. This is where the name “Ashless” comes from. Oils containing this type detergent have a characteristic Ammonia odor. Ashless detergents were used in the first generation of Bombardier XPS engine oil. The formulation was later changed to a low ash type detergent because of the higher temperatures generated by the 787 engines. Low Ash type detergent/dispersants are used in most API-TC, Jasco FC and ISO GC certified 2-stroke oils. These oils are designed for air-cooled high performance engines that operate under severe load/temperature conditions. Low Ash detergents can keep the deposits to a minimum at ring land temperatures as high as 400 deg/f. These detergents are manufactured from compounds of Calcium and Magnesium (heavy metals). After these compounds (Calcium Phenate or Magnesium Phenate) do their job, they burn away, forming a heavy metal salt (ash) that is swept away during the normal combustion process. Hence, this is where the name Ash-type detergent comes from. Ash type detergents depend on the higher combustion temperatures (787 and 951 engines) to keep the resulting ash swept out. Therefore, the use of these high performance oils in outboard or other mildly tuned 2-stroke engines is not recommended. Some manufacturers are using a combination of detergent types (Ashless and Low Ash) to provide a broader range of uses for their oil. It is important to note that oil designed to meet TCW3 specs. only (Ashless) will not protect an engine requiring API-TC (Low Ash) type oil. The converse is also true. Using a Low Ash oil in an engine designed for an Ashless type oil only could result in fouled plugs and gummy combustion chambers. When 2-stroke oil is kept in its temperature limits, it provides an adequate protective film between all moving parts. When that maximum temperature is exceeded, the oil film breaks down and usually seizure occurs unless another line of defense is added to the oil mixture. These are the Antiwear agents. These Zinc compounds (Zinc Dithiophoshate) flow in with the oil and are never used unless the base oil breaks down. If the base oil breaks down, they form a protective barrier between the moving parts (usually piston skirts and cylinder walls).
Since all 2-stroke engines partially burn and expel their lubricant in the exhaust, the resulting exhaust residue must be rendered harmless to the environment (air, water and land). All 2-stroke oil intended for marine use and many intended for land recreational use contain Biodegrading agents. These complex chemical compounds allow the microbes found in water and in the soil to consume the hazardous chemicals and oil from the exhaust as they fall in the water or on the ground. These Biodegrading agents do nothing for the performance of the oil (sometimes they even hinder it), but they help assure us that 2-stroke engines will be around for a while. As you can see, 2-stroke oils are a mixture of many different complex chemicals with base oil. Each specialty chemical has a job to do. Care must be taken to assure that these different chemicals detergents/dispersants, Antiwear agents, and Biodegrade agents) do not react or interfere with each other or otherwise impair the function of any other additive. Antioxidants are chemicals that reduce the chance of reaction between the various additives in the oil mixture. They effectively extend the ‘shelf life’ of 2-stroke oils.
Cut4fun
2:34 PM
Ohio
part 3
What does ATP-TC and TCW3 mean?
Specifications for 2-stroke oils are developed from the design of the engine and its intended use (no surprise). Since this type engine has a wide variety of applications its no surprise that the specifications for the oils might vary also. For marine and PWC application there are 2 widely accepted standards for certifying 2-stroke engine oils. These are, by no means, not the only standards for 2-stroke engine oils. The European (ISO) and the Japanese (JASCO) standards have been developed, but these standards are not widely accepted in the country (yet). The standards most used in this country are the National Marine Manufacturers Association (NMMATCW3) standard and the American Petroleum Institute (API API-TC) standard. Both of these standards address the oil ability to prevent wear, keep the engine clean and biodegradability. Since these standards were written for different types of 2-stroke engines it stands to reason these standards would be different. Hence, the oils developed from these standards would also be different. The NMMA TCW3 standard was designed by the various manufacturers of outboard motors (Mercury, OMC, Yamaha etc.). These manufacturers so not utilize power valves, limit their max rpms to about 6800 and have excessive cooking capacity. They also must be able to operate at lower rpms for long periods of time without oil fouling the spark plugs. Although it’s true the performance of this type engine has increased in the last several years, the peak engine temperatures are still relatively low. The use of synthetic base oil in TCW# formulations has extended the useful range of these oils; their detergent system (Ashless) is designed for lower operating conditions. This is one of the reasons Bombardier specifically prohibits the use of these oils in their Rotax engines. The API API-TC standard was developed for Air-cooled, high rpm, high output 2-stroke engines operating under severe load conditions. Although this standard is no longer reviewed and updated since 1993 b the API, it still is in effect today. This standard most accurately addresses the condition Rotax and 2-stroke racing motorcycles and snowmobiles operate under. Almost all these oils are formulated with synthetic or synthetic blend base oils and all use a low ash type detergent. If you walk into a store that handles a variety of 2-stroke oils, it is relatively easy to find TCW3 certified oil. The manufacturer proudly displays that certification on each container. API-TC certified oils, on the other hand, are very difficult to find. There are two main reasons for this. First, many small API-TC oil manufacturers can’t or won’t spend the money (about $75,000) for the testing and certification process. Second, most engines requiring API-TC oils are for racing applications (Motocrossers and Crosscountry motorcycles) and don’t offer warranties with their engines anyway. The owner/operators of these machines know what oils work and don’t work. They do not need the API-TC certification on the bottle to help them decide what oil to use. There are many really good API-TC type oils on the market that have never been certified as such. Bombardier/Rotax is the only manufacturer that API-TC certified oils. The TCW3 market is about 10 times the size of the API-TC market. Outboard motor manufacturers require the use of TCW3 certified oils to maintain their warranty. With this great volume in oil sales at stake, it’s easy to see why TCW3 manufacturers can afford to certify their oils.
Rotax’s Position on What Oil to Use
As we all know, Bombardier requires that an API-TC oil be used in their engines. Most other PWC manufacturers allow the use of TCW3 in their engines. So, what’s the difference? A PWC is a PWC, right? No, it’s not! Rotax marine engines evolved from their very successful snowmobile and motorcycle racing designs. These engines produce more power/cc than any other PWC manufacturer’s engine. Rotax designs these engines to work harder and run hotter than other brands. They simply need more protection than TCW3 oils can give. Those that use TCW3 oils are risking high temp. Seizure if the engine cooling system plugs or and internal fuel filter plugs (lean condition). These things may not happen very often, but when they do, it’s better to have a little extra protection that only a TI-TC oil can give.
Cut4fun
2:34 PM
Ohio
part 4
So, what’s the best oil to use?
I truly believe there are no bad oils anymore (well, maybe a few really cheap ones are not so good). Most problems with oils are the result of misuse. I had a friend once that insisted on mixing STP with his premix. He swore his motor made more bottom end with STP in the fuel. Well, it may have, but he invested considerably more $$ in spark plugs than just about anyone else on the planet. He was also responsible for single handedly stunting the growth of the entire mosquito population in southeast Texas (thank God he quit riding). I hear a lot of complaints about the high cost of some 2-stroke engine oils, mostly Bombardier XPS. Well, I have to agree, it isn’t cheap, but neither are any of the other API-TC oils compared to the TCW3 type oils. Unfortunately it just costs more to manufacture API-TC oils than TCW3 oils. Despite its relatively high cost, I cannot recall any Rotax engine failing because of XPS oil. XPS oil was a joint development of Castrol and Bombardier. Bombardier wanted a ‘universal’ high performance engine oil that they could use in all their recreational products. That meant oil would flow freely at –40 deg/f and still maintain sufficient film strength at 350 deg/f. The first generation of XPS (1995) was formulated using Ashless detergents; this allowed the Rave valves in the then new 787 motor to stick. The formula was later changed (1996) to a low ash detergent that eliminated the rave valve sticking problems. There have been several minor improvements in XPS since 1996. Castrol remains the only manufacturer of XPS. This is a proprietary blend sold only by Bombardier.
There are a number of good API-TC type oils out there if you chose not to use XPS. If the oil you want to use does not have the ATP-TC certification on the container, contact the manufacturer. Most of them will be more than glad to provide you with information on their products.
Decisions, Decisions!
Well, I hope I answered most of your questions concerning 2-stroke engine oils. I’ve tried to keep brand names and my personal biases out of it so far. However, I, like you, have an opinion. My opinion is based on my 30 years experience working with 2-stroke motors and my relationship with some very knowledgeable people involved in lubrication research. I work for the world’s largest manufacturer of oil additives. We make the additives for virtually all the oil retailers.
Now having said that, here are my recommendations. If you have a Sea-Doo PWC that is still in warranty: Stay with XPS or XPS-DI. Sure there are API-TC certified oils that should preserve your warranty, but in an engine failure the dealer could cause you grief getting your PWC warranted. In my opinion, it’s just not worth the hassle to do battle with them. Stay with the XPS at least until the warranty expires. After the warranty expires, select API-TC oil that carries the certification or confirm in writing the oil you want to use is designed for your PWC. Then find someone else that uses the oil you are considering and get his or her opinion. Do not use TCW3 in your SeaDoo PWC. I don’t care if it’s a full synthetic or your brother-in-law uses it; for the reasons stated above, it will not protect your motor when conditions get tough in your motor.
Choose well, Grasshopper, the life of your motor depends on it!
bwalker
2:34 PM
Montana
That article is about 20 years old and contains a few errors.
It was written just after a time when all the PWC and snowmobile companies reccomended ashless tcw3 oils. Results were disastrous and they are in saws too.
Cut4fun
2:34 PM
Ohio
:risas3:
Just something I read during last winter in down time. Just copied and pasted it for folks that had nothing better to do. :risas3:
Cut4fun
2:34 PM
Ohio
I think this one the part on castor. :p
Castor Based Oils
Mr. Robert Verret wrote : I mentioned a third category of base oils earlier, vegetable or Castor (not Castrol, that’s a manufacturer) bean oil. This oil is derived from pressing oil out of castor beans and distilling it. ‘Bean Oil’ as it is often referred to, has some very unique characteristics; some very good, others not so good. The good is that it is an excellent lubricant. It seeks out hot spots in the engine and clings to those hot surfaces much better than petroleum type oils. The bad is that it does not mix with gasoline easily and it burns ‘dirty’ (excessive carbon/varnish deposits). In the early 70s, before power valves were used, castor bean oil was very popular in racing 2-strokes. Now that power valves are common and we have improved petroleum and synthetic oils, castor bean oil is seldom used anymore. Several companies still market it in the form of a degummed castor oil for racing applications only. It should be avoided for recreational use unless you enjoy tearing your engine down for a top end cleanup fairly often. Several manufacturers formulate their oil with castor bean oil as an additive (antiwear agent) rather than base oil. They blend it with their petroleum and synthetic base oils. When castor bean oil burns, it has an unmistakable ‘sweet’ smell. (end of excerpt)
Like the author of the above text (Mr. Robert Verret) we too have been involved with two-strokes for 30+ years, and we have also spoken with many well educated and well informed folks in the lubrication business. All the experienced and reputable folks we have ever spoken to agreed on the basic qualities of Castor oils. That is, castor bean based oils are not particularly clean burning, do not mix homogonously with virtually any fuel, and are very expensive to manufacture …. But they offer a film strength and lubrication quality that is not matched by any other oil…. Period.
Like Mr. Verret, we also understand that many folks get very emotional about the particular oil brand they use. For us, choosing a 2-stroke oil is all about the science and results … emotion doesn’t matter. For air cooled two-strokes being run at high rpms and high loads, there is no better choice than a castor based oil. During our stint of running the DG Performance race team from 1975-1979, we ran ONLY 20:1 Castrol “R” in every Team DG machine raced out of our shop. The sheer film strength of the bean oil allowed us to run tighter than normal piston clearances, and thereby netting better performance and long term piston life (as a result of less piston "rattling” in the bore).
Castrol “R” was certainly a bit dirty, but it was the best stuff of the day. Of the castor bean oils currently available, we prefer Maxima 927. While it is not “perfectly clean” we have found it to run cleaner than any other bean oil we have used (and we have used plenty). In addition, the film strength of “927” is every bit as good as the Castrol “R” of the 1970’s, with a lot less mess.
In 2010, we built and road raced two 1970 Kawasaki 350 Bighorn Production Class enduros in the western AHRMA road race events. We ran these machines on a 20:1 mix of “927” and 105 octane race gas. While stock Bighorns redline at 6000rpm, ours turned 8500rpm and ran a bit over 100mph. At the Willow Springs track in Southern California, we lapped at 1:52 (an average speed of 80mph). At Willow, our Bighorns were constantly at peak rpm in 4th & 5th gear for every moment of each 15 minute practice session and race. Our race weekend entailed 4 outings for each of 2 days … a total of 120 operating minutes at peak rpm in high gear (per machine) … with not one mechanical issue at all. We respectfully submit that there isn’t any way to subject a vintage two stroke to any more intense abuse than this, and we feel that the lubrication abilities of the Maxima “927” were a fundamental contributor to our weekends of trouble free racing.
After our race season was done, we fitted our Bighorns with street-lighting, and ran the exact same machines on the 100 mile Hansen Dam classic motorcycle ride north of Los Angeles. At this event, we ran the Bighorns on a 40:1 mix of “927” and 91 octane pump gas (most of the ride was done at 3000-5000rpm). The bikes never put out any visible smoke (except at long stop lights) and never came close to fouling a spark plug.
Despite all this very positive experience with a Castor based oil, we openly acknowledge that Castor oils “ARE NOT” necessarily the best choice for all vintage two-stroke applications. Robert Verret’s excerpt below explains that.
Cut4fun
2:34 PM
Ohio
API – TC Oils
Mr. Robert Verret wrote: The API-TC standard was developed for Air-cooled, high rpm, high output 2-stroke engines operating under severe load conditions. Although this standard is no longer reviewed and updated since 1993 b the API, it still is in effect today. This standard most accurately addresses the condition Rotax and 2-stroke racing motorcycles and snowmobiles operate under. Almost all these oils are formulated with synthetic or synthetic blend base oils and all use a low ash type detergent. If you walk into a store that handles a variety of 2-stroke oils, it is relatively easy to find TCW3 certified oil. The manufacturer proudly displays that certification on each container. API-TC certified oils, on the other hand, are very difficult to find. There are two main reasons for this. First, many small API-TC oil manufacturers can’t or won’t spend the money (about $75,000) for the testing and certification process. Second, most engines requiring API-TC oils are for racing applications (Motocrossers and Crosscountry motorcycles) and don’t offer warranties with their engines anyway. The owner/operators of these machines know what oils work and don’t work. They do not need the API-TC certification on the bottle to help them decide what oil to use. (end of excerpt)
The truth is that API-TC oils are also top level lubricants that have excellent film strength, and are much easier to “live with” than Castor oils. Besides being somewhat cleaner than bean oils, the API-TC oils will also mix “homogonously” with gasoline, and have little or no tendency to separate. For vintage machines that spend very little time held at peak rpm (in the higher gears), API-TC oils are the better choice. Among these oils, our favorites are Yamalube R, Kawasaki K2, and Maxima Super M.
About the Engines Lubrication “Needs” - A two-stroke engine actually has two very different kinds of lubrication needs. The lower end crank and rod bearings prefer a slow drip of a very heavy viscosity oil, while the top end parts wear best with a deluge of a very lightweight oil. Since these are two very opposite lubrication needs, you have to choose whom you want to please. For most two-stroke owners, it’s a no brainer. You can buy 100 cranks and crank bearings that will all offer the same performance, but every owner wants to do whatever can be done to preserve a good running piston / cylinder set. Given all this, heavier premixes of lighter viscosity oils are more desirable to most owners.
About Premix Ratios and “Oil Migration Time” - Oil Premix ratios are another subject that some folks tend to get emotional about … and like oil brand choice, our choices are about science and results…not emotion.
The objective of the premix ratio is to maintain a certain level of “oil-presence” in the engine interior during it’s average “operating-use” cycle. But how does one measure or assess the “oil-presence” … The most effective way has been with a radioactive additive. We explain below.
Trying to keep it simple…here is how it works. A test lab sets up an engine on a dyno stand, and begins feeding the engine a premix of an oil that has a specific level of mixed-in radioactive additive. As the engine is run, a Geiger counter at the exhaust exit measures the amount of radioactive material being eliminated. In this way, it is possible to factor the amount of radioactive material being put into the engine, verses the amount being sent out the exhaust. The net result is the amount of “oil-presence” inside the engine. In short, these tests showed that the oil-presence in the engine is a function of the operating rpm. That is, the “oil-presence" inside a two stroke drops significantly as the operating rpms increase. What this means is that an engine being run at 4000 rpm can maintain a very healthy and happy level of oil-presence with a 40:1 premix. However that exact same engine being run at 8000rpm needs to have a 20:1 premix to maintain the exact same level of oil-presence inside. This is why our 350 Bighorn road racers ran happily on the public roads on 40:1, but needed 20:1 for our sustained high rpm racing use. It bears noting that in both the 40:1 street and 20:1 racing situations, our Bighorns made no visible exhaust smoke at all, except when they were held at idle speeds for a long time.
A further example of this is shown in the carbureted two-stroke 951cc SeaDoo watercrafts of the early 2000s. In an effort to reduce the smoking during initial take-offs, SeaDoo engineers setup the oil injection systems to deliver no oil at all at idle speeds (and we mean zero oil). The logic was that at idle speeds there is virtually no oil migration at all. The high oil presence from the previous high speed runs was enough to allow the engine to run happily at idle for 10+ minutes with no oil at all being added…. And it worked great.
The lesson here is that your premix ratio should be a function of the average operating rpm that your vintage two stroke runs at. If you are at peak rpm all the time, 20:1 is a good idea. However for recreational level riders that don’t “scream” their engines constantly, leaner premixes will yield excellent long term wear.
nder engine will seldom restart.
Cut4fun
2:34 PM
Ohio
About Oil “Film Strength” and Piston Seizures - Many people believe that piston seizures occur when engine heat causes the piston to expand larger than the size of the cylinder bore.... but surprisingly this is not true.
If you could freeze your engine "in motion" in the middle of a long full throttle pass, and disassemble it for micrometer measurement, you would find the piston to measure at a .0005" to .001" press fit into the bore. That's right, a slight press fit! The reason that it doesn't seize is because the premix oil has such a terrific film strength that it acts as an irremovable buffer between the piston and the cylinder. That is, the bare metal surface of the piston never actually touches the bare metal surface of the cylinder because the oil stays between them. Many mechanics have experienced this phenomenon while cleaning a freshly bored cylinder in a solvent tank. Completely dry without any cleaning solvent, the piston moves through the bore with difficulty. However while rinsing a cylinder bore with cleaning solvent, the piston glides all the way through with no resistance at all. This is because the solvent acts as a film between the piston and cylinder.
A piston seizure can only occur when something burns or scrapes away the oil film that exists between the piston and the cylinder wall. Understanding this, it's not hard to see why oils with exceptionally high film strengths are very desirable, and why maintaining a proper oil-presence is also desirable. Good quality oils can provide a film that stands up to the most intense heat and the pressure loads of a modern high output engine. Here again, we mention that “absolutely no oil” has a stronger film strength than castor based oils.
About 100:1 Premix Oils - Since the 70’s there have been repeated advertising claims made by various oil brands claiming that their oils can offer suitable lubrication for competition two-stokes on a 100:1 or 80:1 premix. In many cases, these claims are “supported” by testimonials from various users. Despite the oil makers claims, and the sincerity of the testimonials … it’s not so. Running a 100:1 premix would be much like running only 2 quarts of oil in your truck, expecting that the quality of the oil can make up for the quantity …. It cannot….. no matter how good the film strength is “claimed” to be. The truth is, many two-stroke engines can “operate” on a 100:1 pre-mix so long as rpms are kept very low (as might be the case on a novice class open bike). But the first time that 100:1 engine makes an extended higher rpm run … it will lose the mathematics of oil migration, and score a piston. There is just no way around the math.
About Oil Injection - A majority of vintage street and recreational based 2strokes were manufactured with an oil injection system that eliminated the need for pre-mixing fuel. Oils made for oil injection use have a considerably thinner viscosity than oils intended for premix. It is unwise to use a premix type oil in an injector because a premix type oil can have difficulty passing through the small orifices in many oil-injection systems. On the same tack, it is a very bad idea to use an "oil-injection" oil in a premix application because the reduced viscosity will not offer the lubrication needed in a pre-mix situation
Within oil-injection systems, there are two types. The first is a simple "fixed feed" oil injection pump that is driven entirely by the varying rpms of the engine. At low rpms, the pump rate is slow, and at higher rpms, the pump delivers more oil simply because it is being spun faster. Unfortunately, pumps like this generally deliver much more oil than is needed at idling speeds. This is a particular problem for street bikes that often sit at stop lights in street traffic.
To relieve the excessive low speed over oiling of a fixed feed pump, manufacturers fitted, "cable operated" oil injection pumps whose oil feed was varied by a cable-driven valve connected to the throttle. The cable operated pumps have a much broader range of oil output ability. The average cable operated pump will feed an 80:1 - 100:1 oil ratio at idle speeds, and a 32:1 -50:1 ratio (depending on that particular engine's peak rpm) at full throttle. At the same time, many of these cable-driven oil injection systems had "divided feed" lines that delivered some of the oil to the inlet port near the carburetor, and other lines that fed oil directly to lower end bearings. With this, split feed system, less total oil could be injected because less oil was being lost via atomization with the fuel/air mixture.
In truth, many of the cable driven injection systems did a great job of delivering adequate lubrication, along with very minimal smoking. But sadly, these injectors had several significant down sides. Those are (in order of importance):
1) No warning system if the pump failed or stopped delivering oil
2) No warning system if the cable connection malfunctions or becomes disconnected
3) Air Leak risk at fitting bolts that become loose
4) Reduced oil delivery caused by a leaking fitting
5) Oil delivery blockage at one of the many small orifices
For these reasons (and more) many owners opted to remove their problematic oil injection system and simply pre-mix the fuel. This worked fine for Enduro/off-road applications where long idling and low speed smoking are not issues. However for street machinery, the problem of low speed smoking was still a problem that had to be dealt with.
