Saw Collector
OPE Member
11:58 PM
Here
Why didn't blue marbles win? Did it loose any marbles?
It wouldn't stay running somewhere past 4 hours at 300:1. Others exhibited this too. Get hot, loose compression then restart only to run a few then die again. To keep things fair they got two refires. The Blue marble unit had a minimal score and ran fine in normal operation after testing on 40:1 mix. There once was a video of my nephew just working the daylights out of it after the testing.
There was one oil that, due to certain circumstances, the run die, run die went on for several tries so nobody could say I was biased against it if that information was to find its way here. Which its not.
Moparmyway
Its just a saw
11:58 PM
In a meeting
Saw Collector
OPE Member
11:58 PM
Here
Seems allmost magical
Ditto
I may have to bite the bullet and get a gallon this fall. Like I stated, because they make claims similar to Blue Marble which turned out to not be snake oil as some claimed without ever trying it, I'm definitely wanting to test it.
Big_6
11:58 PM
NJ zone 36, PA zone 3D
After the Ida storm, I recovered my underwater Precious 044 MMWS.
So after removing the oil,gas,water fuel blend I getter running!
Whose to say a few more H2o molecules won't help the
Xtra banana saw spin?
Sent from my SM-N975U using Tapatalk
10:58 PM
Let er eat !!!!
11:58 PM
Do any of you use the Schaeffer 9000 synthetic mixing oil? I've read that some use the Schaeffer 7000 mixing oil but my reading is that it (7000) is TCW oil.
They’re both good and work fine in a saw. Very clean burning as well
