Nutball
- 5:22 PM
- Oct 31, 2018
- Mt. Juliet, TN
Why didn't blue marbles win? Did it loose any marbles?
It wouldn't stay running somewhere past 4 hours at 300:1. Others exhibited this too. Get hot, loose compression then restart only to run a few then die again. To keep things fair they got two refires. The Blue marble unit had a minimal score and ran fine in normal operation after testing on 40:1 mix. There once was a video of my nephew just working the daylights out of it after the testing.Why didn't blue marbles win? Did it loose any marbles?
Seems allmost magicalNo sir I have not used or tested that. In fact Ive never heard of it. I am interested in this oil to test but can't get less than a gallon.
https://tribodyn.com/collections/at...nthetic-2-cycle-engine-oil-1-gallon-3-78liter
DittoThis oil is interesting to me because of some of the claims they make.
I may have to bite the bullet and get a gallon this fall. Like I stated, because they make claims similar to Blue Marble which turned out to not be snake oil as some claimed without ever trying it, I'm definitely wanting to test it.Seems allmost magical
Ditto
Remember, stand up and buck no matter the size of the wood. Lol.My wood is small...
Typical for PAMy wood is small...
East Coast in general...Typical for PA
After the Ida storm, I recovered my underwater Precious 044 MMWS.
So after removing the oil,gas,water fuel blend I getter running!
Whose to say a few more H2o molecules won't help the
Xtra banana saw spin?![]()
Sent from my SM-N975U using Tapatalk
They’re both good and work fine in a saw. Very clean burning as wellDo any of you use the Schaeffer 9000 synthetic mixing oil? I've read that some use the Schaeffer 7000 mixing oil but my reading is that it (7000) is TCW oil.
