Saw Collector
OPE Member
12:06 AM
Here
Lol. I read people saying 40:1 and 32:1; i have a “measure rite” measuring cup, it has a measurement for 36:1 so I split the difference to be a rebel and to meet in the middle. There is no scientific or mechanical theory behind it. I have tried different ratios and I am not smart enough to tell the difference.
I ran 32:1 and 36:1 most often up until the testing. Only then was I comfortable at 40:1.
Kiwioilboiler
346 Pic Examiner
6:06 PM
Marsden Pt, NZ
I run 93 milliliters, measured in a graduated cylinder normally used in science labs, to one gallon of fuel. Then I rinse the clinging oil out. Yes imma freak.
Just commit you poor metrimperial weirdo!!!
1 litre of petrol (gas).
30ml of oil. 33:1
25ml of oil. 40:1
20ml of oil. 50:1
I'm sure there are ratios after that but meh....
rogue60
3:06 PM
AU
Another thought too....
Just because someone hasn't had an oil related failure at 50:1 but their ope is worn out in say, 3 years vs 5 years at 40:1 or 32:1 under the same usage, is in fact a slow death oil failure in my opinion. Just a hypothesis on my end as 40:1 is the leanest I run. Now I have read stories of loggers switching from 50:1 to 40:1 and getting a couple more years out of a saw. What oil?
No idea but I'm not surprised if these stories are in fact true.
I agree some think worn through plating worn thin rings massive piston skirt wear clapped bearings on a year old full time work saw as normal lol
Saw Collector
OPE Member
12:06 AM
Here
30ml of oil. 33:1
25ml of oil. 40:1
20ml of oil. 50:1
They don't sell gas by the liter here. Its gallons. The canned VP 94 or Sunoco 95 is in gallons. Im stuck with it. But once I knew that 93 ml was 80:2 in a us gallon I was set.
Saw Collector
OPE Member
12:06 AM
Here
Who measures the US gallon tho? The pump or you?
Don't mess with my system bro. Lol It works for me. Especially when ma math is all worked out. I have a ratio app that is in liters or gallons. Ounces or ml. I pump a gallon, in goes the 93 ml of pure performance, two Gallons..186. easy preasy.
Saw Collector
OPE Member
12:06 AM
Here
My bad. Its 94.6 ml. I round to 95
