KenJax Tree
¯\_(ツ)_/¯
12:45 AM
Over there
I poured the rest of my 50/50 mix of R50 and Dominator cocktail from yesterday in my blower today and I think it smells pretty darn good. Even the neighbor asked what kind of fuel I was using[emoji1]. The R50 provides the rust protection and the Dominator kills some of the Klotz smell.
Moparmyway
Its just a saw
12:45 AM
In a meeting
Hey ......... You might be on to something, mixxing R50 with another oil to cut down on the smell ;)
KenJax Tree
¯\_(ツ)_/¯
12:45 AM
Over there
Why not just buy a different oil instead of mixing it with another?
That's what I did,I didn't like the smell so I stopped using it. Lol
I don't use it. I went out riding with some buddies yesterday and left my oil (golden spectro) on the truck bumper so when we got to the gas station I didn't have any oil so i got some from 2 other guys and there wasn't enough Dominator left to mix my 2.5 gallons so i just mixed it with some R50.
I had some mix left and needed to fuel my blower so I used the rest of it up
In my saws and OPE i use Saber.
jmssaws
Banneded
11:45 PM
Bummer.
I liked gold spectro back in my riding days
Chris Zautner
12:45 AM
New York
ordered some fuel fragrances.... maybe it can overcome bad smelling oils.
let me warn you. Don't put to much in the tank when your first try it. Because you nose gets use to it like body odor after awhile. I made that mistake when I first tried It I got use to the smell and thought I couldn't smell it so I kept adding and adding then I went inside and got the old lady out to the garage because Of course I did a proper piss revving with the door shut. She said All it smelled like was raspberry Twizzlers.
Redbull661
661 hoarder (BlueBallz)
11:45 PM
MN
Oil test update -
I am going to have Tree Monkey mill me up some 8'8" x 10" x 12" oak hardwood cants for the oil test. Figure 9 of them will create a 36" across and 30" down. Figuring that is going to be the best way to keep the wood consistent etc. Given I have 12-14 oils x 3-4 ratios per oil. That is approx 50 x 2 cuts. So figuring I'll need to setup two of these. He wants $600. Anyone want to help out on the cost?
I am working on a thermocouple for the temps inside the cylinder temps and maybe exhaust temps. Also going to try and rig up something to watch the RPMs
I've made up (50) new 36" .404 .063 104dl Stihl chains
list of oils -
benol - 32 36 40 45:1
super techniplate - 32 36 40 45:1
original techniplate 32: 36 40 45:1
R50 - 32 36 40:1
mobil 1 32 36 40:1
honda hp2 32 36 40:1
H1R - 36 40 45:1
Si7- 32 36 40:1
amsoil saber 32: 36 40:1 45:1
dumonde tech 32: 36: 40:1
2R - 32:1 36:1 40:1
trufuel 40 and maybe 50:1
schaeffers 32 36 40:1
opti 2 - 32: 36: 40:1
K2 - 32: 36 40:1
motul 800 32: 36 40 45:1
red armorer 32 36 40:1
that is over 50 tests. I am guessing some will be eliminated because heat and time will fall off making a higher ratio a waste of time to test.
I figure it will may take 2 full days to do them all.
other costs - approx 50 empty water jugs @ .88 per
approx 50 x .5 gal = 25 gal of gas
other odds and ends I'm not sure yet on with the thermocouple or tach setup.
Testing will be done at tree monkey's mill. There isn't enough time to drive somewhere else and I'll be hauling 50 jugs of gas and he's only an hour away. If I need anything his shop is right there. Anyone is welcome to come to this thing...I just don't know when exactly yet. I figure the hotter the better...so I'm not in a hurry...yet. There are some loose ends here and there to still figure out as well.
Moparmyway
Its just a saw
12:45 AM
In a meeting
I ain't throwing away any R50, I ain't buying anymore either. I've mixxed the last of the 2 gallons that I bought, probably use up what's mixxed on Tuesday, then I'll be running some KL200
CR500
12:45 AM
Western NY
I've used victory vanilla in the past..... made the shop at work smell good hahaa
12:45 AM
Oil test update -
list of oils -
R50 - 32 36 40:1
mobil 1 32 36 40:1
H1R - 36 40 45:1
Si7- 32 36 40:1
2R - 32:1 36:1 40:1
K2 - 32: 36 40:1
I'll send you some. I know how time consuming testing that stuff can be. I've spent all day testing one chain.
