full chizel
¯\_(ツ)_/¯
- 6:49 AM
- Sep 12, 2019
- USofA
About 3oz in 30 gallons
My Duramax burns anything oil...lol
You may be onto something!! The tuner will be cheaper though! RA is $$$I probably don’t need the tuner with RA
Just run a corn can like Dunlap does.The herd here is not getting thinned, they hang unless used. If Dominator collects water & rusts, then it’s going to end up as burr oil. I need an oil that’s good for everything and doesn’t need fogging ....... 7000 fits that criterion. I’ve tried a bunch of others, K2 fits also, but doesn’t run as clean as the 7000. I’ll try the Dominator, and see how it holds up. At the end of the day, I don’t care what the oil I settle on is named, but I’ve got to be able to get it easily and it can’t be too costly.
Zero smoke while running, and I mean nothing. Startup is a little, but once the cutting starts, zero.
As far as fumes are concerned, the 3120 muffler was modified for milling exclusively. The PTO side was blocked off and the exit got the fumes up and away from me, I didn’t even get any hint of exhaust.
View attachment 244557 View attachment 244558
I’ve been known to diminish a mufflers ability to “muffle” sound, but the 3120 mod was intended to keep me breathing fresh air while milling. Most every saw that dumps exhaust out the pto side or to the front, will have the guy thats milling, sucking exhaust fumes and pickin 2 cycle boogers from their noses hours after the milling is finished. I’ve gravitated towards getting the exhaust away from the operator, milling, bucking, felling, firewoodin, etc ..........Just run a corn can like Dunlap does.
Not what I was told Mike. It has the new pistons. Everything that the LBZ has. Just detuned. They detuned the first few to be sure everything was all good.
Don't make me go back and dig all that up again.
I have a buddy that pulled one apart.
I would like to see this corn can muffler.Just run a corn can like Dunlap does.
Yes sir. Unfortunately the 04s and 05s had a little overheating problem. They just needed to be tweaked a bit.06 is the same as the LBZ. I had an 04 LLY is why I was asking. I didn’t like the way it did anything but ride[emoji2371][emoji23]
Google corn can muffler.I would like to see this corn can muffler.
Sent from my moto g(7) power using Tapatalk
Did u have a saw done by him Chevy?He doesn't charge anything for all the scratches and sh't on your saw when you get it back...
Hacker...
Silver Eagle?No sir. But I wouldn't let him touch a starter rope of mine. I see in his vids what he does to saws. NOPE.
Not for me...
Mine are all MOFO and Silver Eagle Saws. [emoji106]
