ammoaddict
3:31 PM
Granite Falls, NC
You think its tough sorting through all this to keep up you should see my end. There are 15 trimmers in my garage, 18 saws and now, leaf blowers. My small engine shop buddy gave me 4x4x4 crate full of them. One is a Shindiawa 4 stroker. This is out of hand. :eek::risas3:.
I'll take the saws off your hands to help you out.
Sent from my moto g(7) power using Tapatalk
Duane(Pa)
It's the chain...
3:31 PM
Centre County
You guys should have seen the cloud of smoke coming from the Huskihl seafoam challenge unit when I force fed 20 ml in the carb inlet at wot. I'd squirt till it would almost quit then let her come up to full throttle then repeat. This while running on the 50:1 Saber and a couple ounces of the seafoam in the mix. Calls for 2 oz per gallon in 2 strokes. I put that in roughly 1/2 gallon. Maybe 60% of a gallon. I'll run 5 tanks and have a look. Then it's on. We need to discuss what oil and ratio to no load wfo kill it with.
Saber 100:1 or RA 50:1 just to see when/if total reckless abuse causes all normal attributes to go out the window? just a thought. Use vs. abuse...
3:31 PM
RC fuel with 20% nitro
full chizel
¯\_(ツ)_/¯
3:31 PM
USofA
I remember that on the news last year.
We do hear shooting and fireworks out here in the sticks frequently after dark so I hope they didn't pop him. Let him get all grown up.
He’s probably just a yearling. Someone probably saw it laying in their yard and thought the mom left it let it like everybody does and took it and raised it. Now its big so they just expect to live in the wild now.
3:31 PM
You think it will run on it? I like this idea.
This old beatch isn't part of the high rpm no load testing vs my heavy load testing, to compare residual oil left behind and damage. This is a just because type deal. So that nitro fuel idea im into. I robbed a 2 needle walbro off something for this trimmer that I had already put a kit in and I want it back.
It will probably be very lean quick[emoji23]
3:31 PM
So test over in a hurry. Alcohol requires much larger jetting from what I remember. Much lower BTU so more is needed. Probably not enough adjustment on one of these carbs in stock form to get it rich enough you think?
2.4x the flow so if you can drill a jet out a little that would be good. The nitro at 30-35% actually makes it as rich as Nitro mix will ever get. But it will still make a nice boom with the piston maybe making an exit. I know in an 046 I had it was turning north of 17k out of wood and almost 13k in a cant with me pushing as hard as I could. But it didn’t idle or want to turn off either[emoji23]
