Keith Gandy
Maxima K2 40:1 87 Pump Gas
1:28 PM
Provencal, Louisiana
So, the RA test mule...... Been running it on 40:1 RA mix to see if will clean itself up. Couple tanks so far. It's already cleaning up its own mess. I swapped that power head into a straight shaft twin line unit from another weed eater featherlite and I'll be using it all summer. It will have a steady 50:1 RA diet going forward. At the end there will b4 and after pictures. I'm pretty damn impressed. There is nothing but bare piston above the ring already. The side of the piston that is. Have not peeked at the crown yet. I'm thinking these oil tests will be more for you guys than myself going forward. I'm about 75% sure my oil search is about to be over. Dominator or K2 better REALLY impress me to move the needle. If all three ran the tests, and are still usable, the cleaner of the 3 will be my go to oil. Outstanding protection and superb cleaning ability. What else can we ask for in an oil.
That dang Red Armor!!:D:campeon::aaaaa::applaudit:
Keith Gandy
1:28 PM
The red armor for the win phrase you've used in the past definitely comes from a place of actual usage and visual inspection on your end. None of this I heard from so in so or whatever. I see for myself why you like it. I see what you have seen.
Ive taken alota equipment apart Ive ran it in and hadnt seen anything I didnt like. Not sure why Ive started using K2
Keith Gandy
1:28 PM
Need to get some. I'll rust test everything I test eventually.
Correction on something I said yesterday. Its Dominator that smells nearly Identical to Red Armor, not Dolmar. The dolmar smells like sour milk if you Huff it. Not that any of this means anything besides I have a screw loose.
I vote for LOOSE SCREW!!!just kiddin buddy
ammoaddict
2:28 PM
Granite Falls, NC
Refresh my memory fellas. Is Red Armor full synthetic or blend? I thought it was full but I can't find anything that says it and Im not going out to the garage to look at the bottle tonight. Thanks
Semi synthetic
Sent from my moto g(7) power using Tapatalk
2:28 PM
It's somewhere in this thread. The MSDS sheet showed it.
Maybe Keith G will chime in and help.
I think ECHO took out the esters in the new formula.
