6:15 PM
Do all single ring pistons have a thicker ring?
I think the 372 is the only one that changed from 1 to 2 rings over time. So not anything real to compare to. I don’t know of a single ring piston that is 1.2 other than some of the CCC Wisecos.
Kiwioilboiler
346 Pic Examiner
10:15 AM
Marsden Pt, NZ
Someone should test oil in a weedeater for a day or 2 so we know what oil performs best in hard working chainsaws for a couple thousand hrs... :roto2nuse:
I know you thought he was OTT Rogue, but coz of respect for your IRL experience he did just that, and your Castrol dinosaur stuff did so well in the weedeaters that it's now one of his personal choices.
So the test lab and the bush maybe align?
I didn't follow over to the new yarn but that much I do know.
kingOFgEEEks
6:15 PM
Tioga County, PA
The real question is, what ratio do I mix the fuel scent additive at with my oil, so I can smell like grapes instead of burnt oil when I'm done cutting?
Hundred Acre Wood
Full-time Slacker
6:15 PM
On the hill
You've added a whole new dimension to the oil wars. It's now a 3-dimensional matrix of oil, ratio, and scent additive. So much more room to do battle!
5155
6:15 PM
pa
Husq 50something single ring, and stihl 034 double ring use the same size rings.
Does a dbl ring set keep piston square to bore netter than single? Resulting in slower skirt wear.
Not really a question, just thoughts while working. I run with what got it here, mostly.
Never thought of heat transfer, glad I checked this oil.
When does more heat=more power
trump more heat=more wear?
I better take a nap lol.
NateSaw
6:15 PM
Maryland, USA
But with the pipe is should be slightly more funner!!! :aplastao: :ARMS1:
and sometimes ya just have to be a bit different.
Oh it's funner lol. It goes 50 on the flats, holds 35 up most hills. 70cc bb kit, light porting, squished and decked head, 21mm dellorto and stock brakes🤣🤣🤣 But it don't cut wood😬
PissRev
6:15 PM
Ga
20 tanks (approximately 12.5 gallons) of Husqvarna XP+ 50:1 with 90 octane E0 ran through a Shindaiwa EB810 blower. Previous oil was mainly VP syn.
It's hard to tell but the piston had a nice coating of oil.
20230329_182214.jpg20230329_182347.jpgView through spark plug hole.20230329_182648.jpg
FergusonTO35
6:15 PM
Boonesborough, KY
No more Stihl Ultra for me! I used it last summer because I was given several bottles of it. Seemed to work good when fresh, gave the fuel a greenish gray color. Yesterday I filled up my saws with a batch of fuel left over from the fall, stored in a sealed can with healthy dose of fuel stabilizer. It had a gross orange color and acrid smell, so instead I poured it into the waste oil.
PissRev
6:15 PM
Ga
I will buy six pack when I buy a new piece of equipment to double the warranty, but all I use it for is drill bit lube or something else like lubing my hedge clipper blades. That's about all it's good for.
thedude74
Bonafide & Stuff !!!
3:15 PM
Alaska
Husky 545 and 550 have a single 1.2 mm ring....at least according to Meteor. Didn't see any other single 1.2mm piston listed.
kingOFgEEEks
6:15 PM
Tioga County, PA
I use it for assembly lube. That's enough for me...
