RI Chevy
- 5:46 AM
- May 7, 2016
- earth
I use RA. It was @Keith Gandy approved.
Lol
Lol
You’d be fine, mix it at 25:1Yikes!!! Well I guess I will use something else. I'll use the rest in the tractor to dose the diesel fuel. Yea I know that's really tcw3 oil, but it will be ok. It's an old school diesel it will burn anything and like it.
It's not. I went out and looked at the case and a bottle. I could've sworn it was rated. But citgo sea and snow is. And this stuff leaves less carbon buildup than sea and snowSome oils on that list surprise me.
I couldn't find the Dolmar oil on the list.
I mix 32:1 now. Not far offYou’d be fine, mix it at 25:1
I figure as cheap as the Lucas is. I’d just dump it in the bar oil tank. If I need 25:1 to feel safe I’ll just go with a different oilIf ya don’t have much left I’d burn it up. Still would probly go 25:1 on it though
I think I have half a quart or is it enough to maybe not quite mix 2 gallons?If ya don’t have much left I’d burn it up. Still would probly go 25:1 on it though
Yea I'm not useing it. It will go in my dieselI figure as cheap as the Lucas is. I’d just dump it in the bar oil tank. If I need 25:1 to feel safe I’ll just go with a different oil
Only reason I say that is because a well known member here runs the snot outta Lucas at 25:1 and has no issuesI figure as cheap as the Lucas is. I’d just dump it in the bar oil tank. If I need 25:1 to feel safe I’ll just go with a different oil
What ratio you run on that benol deets?If ya don’t have much left I’d burn it up. Still would probly go 25:1 on it though
I’d buy thatOnly reason I say that is because a well known member here runs the snot outta Lucas at 25:1 and has no issues
He just needed to soak it in cider.The doctor...he said it started to hurt pretty bad.
I know @mdavelee was useing it milling a few years ago, seemed to be happy at the time.
Ok so I am now on the search for some more oil. I am thinking of useing echo Red Armor this time.
@Moparmyway has had some interesting finds as well after using Lucas. It leaves saws very dry as Jake said. Not real good to use. Much better options.
NOT good, cause like us all I have several saws. It will be months between start ups!!If you run real rich like 24:1 it is enough oil. If it sits for a month or two it doesn’t seem to leave anything behind. It’s definitely not a storage oil.
Not good. I'm on the hunt now for a different oil. What's left in my mix will get dumped in my k10 Chevy. I have more saws than i can use like most of us. I will dump every saw and run them all till warm then put up. I may just get a bottle of Husky XP oil till I find what I will run for awhile.Two weeks sitting and the Meteor aluminum piston was corroded.
I only use it as assembly oil, straight outta the jug. It’s so thin it runs like water. I’ll never buy it again
