KenJax Tree
¯\_(ツ)_/¯
- 11:30 PM
- Dec 31, 2015
- Over there
Thats crazy..4 seconds between 87 and 90, but 15 seconds between 90 and 93.
Really hard to do on a mill. If I tune on the edge like normal cutting by the end of the cut it's cooked. These are short cuts for milling but a square foot of wood cut in 25-30 seconds where that takes 10 seconds for a cross cut or round about.Do you think you would see the same results if you tuned the saw to the max RPM (in the wood while cutting) for each type of fuel
Reason I ask is that sometimes I think that tuning to a particular RPM is kind of handicapping the fuel
what the hell did you do to an ms280? evil genius.
Is the polaris an injector oil they were using as mix maybe ? The injector ones are much thinner .klotz tc-w3, says pass at the end
Polaris says fail at the end
interesting
Yea, but no load?All the time milling.
Lucas may not be the best in a snowmoblie, but in OPE its more than good enough.Damn. Doesn't look so good for the fd cert citgo sea and snow or the Lucas I bought. Oh well. Let 'em fry. I ain't throwing it away
