bwalker
1:09 AM
Montana
I ran 20-25 tanks of lawnboy ashless oil at 32:1 and husqvarna ls or xp at 32:1 in my 545, I bucked and limbed about two dozen maples with it the fuel was marathon 87 ethanol free
me thinks the plug looks fine this saw ran for the better part of a summer and fall doing firewood duty. Sorry if the pictures are a little fuzzy it is hard to focus on a plug this small
Looking at the end of a well used plug won't tell you a whole lot other than in a very broad sense.
Is a 545 an AT saw?
mdavlee
Hillbilly grinder
1:09 AM
TN
Chain brake rub on it ? A couple 3/16 pop rivots clear ? i like to run screens ,the muffle some noise and keep crap from falling in there .The 288 shield clears if put exactly where i placed it ,any further back hits the brake handle on a 440 .
It will clear on a 44. 46 is real tight,
jake wells
no longer here
12:09 AM
ky
Is a 545 an AT saw?
The 545 is autotune, btw the spark plug is a CMR6H ngk.
Moparmyway
Its just a saw
1:09 AM
In a meeting
Just an added ..............
You could trim away the base a little more, and weld it lower so it clears better
junkman
Crush it
10:09 PM
pacific northwest
e
How are you replacing the screen if welded on ? that's why i use 2 pop rivots ,just drill them out and put new ones in .
Moparmyway
Its just a saw
1:09 AM
In a meeting
e
If you need it lower, there wont be any place to pop rivet anything on.
I havent needed to change any screens yet, so I took a roll of the dice here. I didnt want any cracks for exhaust to blow out of, could melt the plastic, so I welded it with the screen under the deflector. A new deflector is $5, so if I do need to replace that screen, I'll just cut the deflector out of there and weld up a new one.
Have you had to replace any screens on yours ?
junkman
Crush it
10:09 PM
pacific northwest
Not yet ,i do not cut every day though
mdavlee
Hillbilly grinder
1:09 AM
TN
I welded the outer edge and drilled some holes on the one I did. Tacked nuts on the inside of the muffler and put a screen in and tightened it down.
Moparmyway
Its just a saw
1:09 AM
In a meeting
I will be doing something different to the inside of one of my front covers .............. someone that I know came up with an idea that I want to try
