Motorhead
Cantre Member
6:49 AM
Tampa Fla.
The label on the back is confusing.Especially the Spanish part.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
5:49 AM
Provencal, Louisiana
Not that i would know any better keith but the things ive ran that stuff through ran much better than they did on motorsickle oil.
Thinner oil with less drag and combusting easier. With the race oil u gotta adjust ratio. Kl200 is strong oil with viscosity in the 20s. I run kl200 @ 42to1
sawmikaze
6:49 AM
steeltown
Thinner oil with less drag. With the race oil u gotta adjust ratio. Kl200 is strong oil with viscosity in the 20s. I run kl200 @ 42to1
Im gonna mix K2 or HP2 at 50:1 in the next few days and after work one day this week im gonna go help one of my mang's cut up some big wood for firewood and see if i can blow up a ported saw at that ratio.
bwalker
6:49 AM
Montana
That is boat oil,they have a air-cooled oil that is good.
Notice where it says " can be used in chainsaws..etc WHERE RECCOMENDED?"
The problem is no chainsaw mfg reccomends boat oils..
Most of the mfg's of marine oils do this and it's very misleading to people that are not knowledgable.
Keith Gandy
5:49 AM
I cant think of an oil that i wouldnt use really. I just have more favorites over others. When looking at the supertech they made a universal full synthetic in a silver bottle with a black cap but the one I posted is air cooled full synthetic silver bottle with red cap and is dark blue oil. 1.62$ per 6.4oz. If i was in busniess and used alota oil I would have to give it a long term try
sawmikaze
6:49 AM
steeltown
We got the grey bottles with the red cap , do they make it in bigger bottles ?
smokey7
6:49 AM
Detroit
I really am curious about some input on the mystic sea and snow and what it is and can be used for. Please help
paragonbuilder
6:49 AM
Norwich, CT
Your going to have to tune it lean to blow it up...
Cut4fun
Redneck Chainsaw Repair
6:49 AM
Ohio
smokey7
6:49 AM
Detroit
It's fd certified. I'm using 2 gallons I bought right now. Seems good, but I just started
I understand it's certified oil and is a air cooled oil. I was led to believe it work well in my modded jetski. Now it's a watercooled motor under heavy load with major rpm swings. If low ash oil will not work well in a outboard how would it work well in my ski?
I'm looking for a good oil to protect better then tcw3 in my ski. It sounds like some are using it as a dedicated air cooled saw oil too. Is it a air oil or a water oil? And is it like what some are marketing as a multipurpose oil. I'm so confused in my skis application and oil required oil. Oem saws tcw3 and builders are saying go with a good tcw3 or it be better to use a low ash. Which is best as you guys see it.
CR500
6:49 AM
Western NY
Wow come back from a fishing vacation and soooo many pages to read. :risas3:
I'm just curious as I have never read anyone using this stuff anywhere. Anyone?
Torco http://www.torcousa.com/index.html
T-2R JASO-FC / ISO-L-EGD http://www.torcousa.com/torco_product/t2r.html
GP-7 JASO FC / ISO-L-EGD http://www.torcousa.com/torco_product/gp7.html
I've used a couple qts of GP7 at 32:1
By for the least offensive smelling oil I've used.
It was being ran in the 441 I have mostly. The other saws au the time do not mind it.
stihl saws
You can always justify another saw.
6:49 AM
Virginia
It's not going to blow up and will run fine if tuned correctly. Please change your avatar, it's like watching one of those Zulu movies....again.
bwalker
6:49 AM
Montana
