skidooguy
Genuine smartass
6:55 AM
Wyoming
That's great. Yamalube also used to be citgo as well. I don't know if it still is or not.
CR500
8:55 AM
Western NY
I believe not anymore, Also Mystik oils were sometimes labeled Citigo
Also on the bar oil subject Mystik offers a bar and chain oil at around 16 bucks a gallon
8:55 AM
I used to run citgo 2 cycle in every thing I had from bikes to saws to sleds. Still run it in my stock sled. The turbo sled gets redline as the builder asks and recommends.
I'VE got 2 gallons of citgo oil to burn up. I'll post some tear down pics of the current stuff I'm using before I switch
jake wells
no longer here
7:55 AM
ky
i checked the msds on the walmart supertech synthetic 2 cycle air cooled oil and it has a lot of different ingredients.
its blended by warren oil, i tried loading the page to here but it wouldn't let me so i took a photo of it instead.
jake wells
no longer here
7:55 AM
ky
the last 3 items are sometimes used as octane boosters or anti knock agents i think, its been to many years since chemistry class in school.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
7:55 AM
Provencal, Louisiana
Terry Syd
10:55 PM
Comboyne, NSW Australia
Yep, I did an article many years ago on octane boosters and recognized the additives. Toluene as I recall was called Methyl Benzine in some literature. We used to get it in small 20 liter drums and could add it to our fuel. I even remember adding some acetone to raise the octane rating. Of course, you needed a sufficient compression ratio to actually utilize the octane rating, otherwise you could loose power, but it was legal whereas methyl alcohol wasn't.
There wasn't much in it other than a desire for reliability. Even if you ran straight methyl alcohol you could only hope for about a 6% increase in power over gas/petrol unless you bumped up the compression - then you might get an extra 15%.
