- 7:15 PM
- Jan 22, 2022
- MO USA
Evening guys.
Did up a few blades the last couple days, kinda getting it figured out.
The setter is definitely going to take some practice, but I've got it down to about 7 minutes per blade at this point without trying overly hard.
It seems to be doing a pretty good job and is fairly consistent, I did over-bend a couple teeth out of a half dozen blades, but I just pushed em back with a rod and reset em.
Right now I'm trying to get the stop adjusted so I can just squeeze it all the way and have it turn out right...... I have my doubts it can work that way, due to inconsistencies in the blade metal....but possibly it'll be good enough.
So far, when I try it that way a few teeth per blade just won't bend far enough... probably not a big deal since a few under-set teeth won't screw with the finish of the cut like an over-set tooth can.... least wise that's my assumption.
The grinder is very slow.....but that's okay, because once you get it setup right it does it's own thing, and a guy can go do something else for 10-15 minutes.
The auto-kill thing you stick on the blade doesn't inspire much confidence, so I just work on something nearby so I can babysit it.
Also, going to have to file the cam a bit more because I'm seeing micro inconsistencies in the gullet that I don't like.
They say that can cause blades to crack due to it giving them a place to start cracking.....idk, but I figured it won't hurt to make it better.
Haven't done any more sawing with the resharpened blades.....that's next.... maybe tomorrow.
