- 6:58 PM
- Jan 22, 2022
- MO USA
Sounds right in terms of the quality we are getting these days.Good thought.
I checked it, & seems okay to me.
I'm thinking woodmizer sent me a bunch of blades with bad set.....I found some blades I bought further back, and they're cutting just dandy.
All the new ones are diving even though my blade guides are tilted up slightly.... these older blades I'm running right now are climbing a tiny amount just like I'd expect with how my guides are set currently....and I'm not getting any chatter.
Anyways, I ordered a blade setter today so I'll check the offending blades when it gets here and see what's up.... I'm betting they're outta whack.
I ordered the woodland Mills RS30 PRO grinder & setter combo.Sounds right in terms of the quality we are getting these days.
My day is metal filled. I expect it a little when cutting cedar logs, but deck screws destroy a blade. 2-3" in no indication. 2 blades in do I go for a third or put it on the trash pile?
What did you get for a setter? I have a cat claw dual tooth. I like it but it hurt to buy.
Very interested in seeing what you think about that setup.Grinder & setter came today, now we gotta put it together & figure out how to make it go.
Will definitely give my impression as time goes on.Very interested in seeing what you think about that setup.
When ya get it figured out I'll send ya some blades to sharpen.
I was pleased.That's a damn good finish.
That's pretty damn good.No grinding today, but I ran my first resharpened blade sawing oak. It's cut a bit over 400 bf and is still going nice and straight......must've done an okay job grinding it, I guess....
At this point it's preformed about as well as any new blade I've run.View attachment 397919
It is.That's pretty damn good.
