- 11:02 PM
- Jan 22, 2022
- MO USA
Thank you sir.Neatest looking lumber stacks I've ever seen.
Oops.... I didn't mean to teach anybody anything.....lol@Sawdust Man I kept going back to this picture you posted in my mind.
My mill is small. Only has the ability to cut down 6" till I hit the top of cant. But I used this to cut a poplar 10x10 this evening. As you well know, cutting a 2x into 2 1" boards can be a challenge if the lumber wants to bow up or down much. Once I was down to a 6x10, I left the boards on the mill till I'd sawn the whole cant up. Nothing moved at all. Thank you for teaching me this trick.
I appreciate you posting about your milling adventures. I need all the help I can get.Oops.... I didn't mean to teach anybody anything.....lol
I almost always leave the boards on the cant.... as long as it's not a piece with a really bad attitude, it'll stay put with the weight of the boards.
If it's a bad piece.... just go ahead and get mad...and plan on being defeated....![]()
You're welcome boss!I appreciate you posting about your milling adventures. I need all the help I can get.
Did you figure out what was causing the odd cut you posted about?You're welcome boss!
I enjoy bragging as much as the next guy....![]()
No, I decided not to try too hard to figure it out while I was cutting the white pine because that's something I'd never milled before, so I don't necessarily know how it outta behave.... I thought maybe it's just what happens when you saw wide white pine?Did you figure out what was causing the odd cut you posted about?
I can see sappy wood causing some odd happenings.No, I decided not to try too hard to figure it out while I was cutting the white pine because that's something I'd never milled before, so I don't necessarily know how it outta behave.... I thought maybe it's just what happens when you saw wide white pine?
Probably wishful thinking, but I figure eliminating the variables is a reasonable approach.
Yes, that's what several people on the other site thought could be my problem.I can be sappy wood causing some odd happenings.
I've talked to a few local guys who mill a lot of pine. Most use diesel fuel for blade lube.Yes, that's what several people on the other site thought could be my problem.
I'm thinking something mechanical, or a hormonic issue....but we'll see what happens when I start sawing again tomorrow or Friday.
I mix powdered laundry soap into my lube water.... generally it's sufficient, but when I get a really goopy pine I'll spray diesel on the blade periodically to keep it from gumming up.I've talked to a few local guys who mill a lot of pine. Most use diesel fuel for blade lube.
I use a little Dawn in my water. Haven't had a problem.....yet. LolI mix powdered laundry soap into my lube water.... generally it's sufficient, but when I get a really goopy pine I'll spray diesel on the blade periodically to keep it from gumming up.
Never tried running straight diesel, it probably works wonders.
Slick!I put a router sled together to run on the mill rails. It could use some tweaks but the initial results were pretty satisfying. The big plank shown was a plain sawn hard maple slab cut at over 2" thick. It developed a severe twist while set aside to dry. The sled brought it back to flat at about 1 1/4" thick, 18" wide.
View attachment 394761View attachment 394762
