What? No bandsaw milling threads?
9:11 AM
@Sawdust Man I kept going back to this picture you posted in my mind.
My mill is small. Only has the ability to cut down 6" till I hit the top of cant. But I used this to cut a poplar 10x10 this evening. As you well know, cutting a 2x into 2 1" boards can be a challenge if the lumber wants to bow up or down much. Once I was down to a 6x10, I left the boards on the mill till I'd sawn the whole cant up. Nothing moved at all. Thank you for teaching me this trick.
Sawdust Man
Manufacturer of Sawdust
9:11 AM
MO USA
Oops.... I didn't mean to teach anybody anything.....lol
I almost always leave the boards on the cant.... as long as it's not a piece with a really bad attitude, it'll stay put with the weight of the boards.
If it's a bad piece.... just go ahead and get mad...and plan on being defeated....:mad:
9:11 AM
I appreciate you posting about your milling adventures. I need all the help I can get.
Sawdust Man
9:11 AM
MO USA
Did you figure out what was causing the odd cut you posted about?
No, I decided not to try too hard to figure it out while I was cutting the white pine because that's something I'd never milled before, so I don't necessarily know how it outta behave.... I thought maybe it's just what happens when you saw wide white pine?
Probably wishful thinking, but I figure eliminating the variables is a reasonable approach.
9:11 AM
I can see sappy wood causing some odd happenings.
Sawdust Man
9:11 AM
MO USA
I can be sappy wood causing some odd happenings.
Yes, that's what several people on the other site thought could be my problem.
I'm thinking something mechanical, or a hormonic issue....but we'll see what happens when I start sawing again tomorrow or Friday.
9:11 AM
I've talked to a few local guys who mill a lot of pine. Most use diesel fuel for blade lube.
  • Like
Reactions: Lnk
Sawdust Man
9:11 AM
MO USA
I mix powdered laundry soap into my lube water.... generally it's sufficient, but when I get a really goopy pine I'll spray diesel on the blade periodically to keep it from gumming up.
Never tried running straight diesel, it probably works wonders.
Ketchup
Epoxy member
8:11 AM
Colorado
Pine sap is oil soluable. I get it out of my clothes with mineral oil. I bet that’s why the diesel
works.
9:11 AM
I use a little Dawn in my water. Haven't had a problem.....yet. Lol
JIMG
10:11 AM
NorthCountry
I put a router sled together to run on the mill rails. It could use some tweaks but the initial results were pretty satisfying. The big plank shown was a plain sawn hard maple slab cut at over 2" thick. It developed a severe twist while set aside to dry. The sled brought it back to flat at about 1 1/4" thick, 18" wide.
maple plank 10:26.jpg
Sawdust Man
9:11 AM
MO USA
