SteveSS
- 7:08 PM
- Dec 24, 2015
- Missouri
I'm trying to find an alternate gasket material to tighten up the squish on an MS260. With the OEM gasket it's at about .032 if memory serves, and without the base gasket it's at .012. There are some pretty old threads on AS about using manilla folders, but then I recall a thread last year when Randy pulled apart a saw that had ingested its paper gasket. The manilla folder is actually a perfect thickness to put me right at .020, but I don't want to hose something up by using it.
So what do you guys use when you need a thinner gasket and machining things is not an option?
