What are you building with your milled wood?
Shawn Curry
Cuts trees in half
7:49 PM
Western NY
What do you use for glue?
Titebond 3 for those. I considered gorilla glue since I was gluing end grain, but I just ended up using a thick coating of titebond. I did use gorilla glue on the miter joints for the boxes.
Mitered boxes for my girlfriend, mom, and sister, and a couple friends. Black walnut, black cherry (my tree), curly English walnut (my sisters tree), and red maple. I used the Matt Kenney "Perfect Mitered Boxes" design that's scattered over several issues of FWW.
cease232
7:49 PM
Montana
Needed a quick handmade gift for the ladies in my extended family. Last year I made wooden kitchen utensils and it was far to time consuming. This was just scrap I had after making a table with some fir I milled up.
Table decor, votive holders.
Shawn Curry
Cuts trees in half
7:49 PM
Western NY
Just curious, why did you use gorilla glue? I use titebond 3 for almost everything. I have a bottle of gorilla glue but I don't even think it's opened yet. Sweet boxes BTW.
Thanks! It was basically an experiment - I've read that it can be much stronger for end grain applications, which normally tend to soak up a lot of yellow glue and starve the joint. I can't really verify that claim in regards to strength, but I can say that the squeeze out cleaned up much easier than yellow glue - after scraping most of it away, the rest cleaned up with a couple strokes of 120 grit sandpaper. The yellow glue that couldn't be scraped away took a few minutes with a palm sander and 80 grit. I think that fact alone is enough for me to favor it for something like these boxes, as sanding all those inside corners isn't the easiest thing to do.
Iron.and.bark
8:49 AM
Getting started on a natural edge small kitchen table.
Router planning on mates wood wizz.
Leaves a pretty good surface. 80 grit on orbital from here.
Need to get filling cracks and shaping it first though.
peter92
10:49 AM
maryborough qld aust
Tim
7:49 PM
Ohio
Wow, seeing all these cool projects makes me want to do woodworking projects. Here are a couple of my nicer projects. My next one will be a three cord firewood shed. After that will be my biggest project yet. A 24' x 12' run in shelter with a small tack room for horses. I'm planning to have the firewood shed done this spring and the run in shelter hopefully before the end of this year.
