Ugly Stihl 064 overhaul
redline4
I'm huge in Japan
11:51 PM
Rosholt Wisconsin
I use a bit of this on the spring, stud and moving parts. It doesn't get thick and gummy in the cold.
I took the easy route and hit the spring with brake clean and compressed air..
And pop it back in place, lining up the small tab and spring end.
Line up the pulley and spring
Pawls in
Spring on..
hacskaroly
2100 Fanclub Member
9:51 PM
Northern Idaho, Ehh
Another case of the dumb.
It's great to have another 2,3 or 4 sets of eyes, I don't know how many times I have put something together only to have to take it back apart to reset a part or find I missed something. What gets me is the extra screws when I am finished, I think little gnomes are playing tricks on me and tossing in an extra screw or two into the parts pile...no idea where they go....
redline4
I'm huge in Japan
11:51 PM
Rosholt Wisconsin
Let's get this *s-wordshow on the road..
I found that the small insert for the oil hose got a bit boogered when I had to drive it out because it had become one with the case.
I used a few assorted nails, pliers and a body hammer to get it back to round..
I found that the perfect finishing fit was my t15..
redline4
I'm huge in Japan
11:51 PM
Rosholt Wisconsin
Pto side seal in.
Need to ease it around the step on the crank before tapping it home
Then bolt up the pump for the last time
2 different seals in the kit must cover changes throughout the series run..
And flywheel side seal in
redline4
I'm huge in Japan
11:51 PM
Rosholt Wisconsin
Steve hooked me up with a fresh slug
Start one end of the clip and holding while popping the other corner in
Having the wrist pin installed helps, keeps it from pushing in too far
I orient the clip opening at the bottom.
Slobber some earl on the wrist pin bearing and put it in the connecting rod
redline4
I'm huge in Japan
11:51 PM
Rosholt Wisconsin
I lay it on its side after putting the piston on to make install of the clip easier.
One thing to note, I forgot to mention piston orientation, the arrow on top points toward the muffler..
Note the ring pin location and ring end tapers..
I start the ring, and roll it around the piston
