- 7:57 PM
- Dec 24, 2015
- Coastal Oregon
No pain no gain, everything is at some kind of risk.
Yep, and packing out in some places is much easier than others.
Does the same science apply on birdcage (not slr) Dolkitas Mr Shot?Really Doc,
Modified in such a manner, it increases the velocity of the port. Which enhances the draw through the motor, allowing it to run more efficiently.
I didn't spend the money for a plasma cutter to go slower.
Saw runs better, job goes smoother, where am I going wrong here?
Any two stroke.Does the same science apply on birdcage (not slr) Dolkitas Mr Shot?
This is what I do too. I also remove any burrs just incase one comes loose.I usually just drill out front of the baffle with a step bit.
That’ll work,I took my custom fuel filter removal tool
And found out the fuel line isn't long enough to allow the filter to come out of the tank..
So, not very gently, I pulled the line through
And it looks good
New filter on
Long forceps work good to ,That’ll work,
Holley accelerator pump check valve is the same, if you got one of those.Some lube...
And I put the line back home
And noticed the check valve is missing..
Yes, the one in my post is for a 046. I just finished putting it back together after taking it apart for a deep clean (super muddy, found at the dump). Have not had a chance to fire it up yet, but with new rings, it seems to have great compression!Is that a front cover for the 046 series saws?
