Ugly Stihl 064 overhaul
Member
12:40 AM
Then there's this muffler baffle...
My initial thought to anything like this is make it go away.
Does anyone have a good reason to leave it?
Yes, well, part of it any ways. I like to take a plasma cutter to the end of the baffle and leave the sides.
This effectively helps pull the snaust out more gooder and I could explain how but am not in the mood for the guy that comes behind and wants to argue the point. At any rate, my testing shows it gives the saw more vim and vigor.
Here's one that has it done in such a fashion...
Junk Meister
12:40 AM
Nebraska
post #60 and 61
When you say circumsnize the end with a plasma --Is the end the side with 3 hole or the one with 4 small holes (that the ex gskt is resting on)?
Member
12:40 AM
post #60 and 61
Well, would you want to be circumcised at the tip or the base? Lol
Just the top plate that has the three holes put in it will do nicely.
Maintenance Chief
1:40 AM
South Carolina
Took the heat gun to it until it got good and warm and stunk like burning possum
And with the trust rubber hammer, drove 1 side apart.
Repeat on the other side
And it's split.
The bearings felt fine when it was all assembled, but apart the flywheel bearing feels very gritty.
I had an 064 lock up the flywheel side bearing while running, plastic cage disintegrated. Luckily no damage.
Vintage Engine Repairs
1:40 PM
australia
Now I'll need to clean parts and put together a parts list..
To circle back to @Glock37 post about the intake and carb box, mine doesn't have callout #6. View attachment 398235
Is that outer ring missing on mine or does the older version not use it?
What part is that on your hand? I saw that in my box of bits but couldn’t figure it out!
Edit: oh it’s the binder for your file LOL! I have what looks to be an identical part. I think mine must be off webbing or a buckle for climbing. I think I threw it out, got a bit of a shock when I saw you “holding” it here! I just woke up,
forgive me LOL
1:40 AM
Correct Eduardo. Some of the older tanks didn’t use the outer, just the inner ring. If you look at your tank at the carb mounting face, the tank has an integral cast in plastic outer band.
redline4
I'm huge in Japan
12:40 AM
Rosholt Wisconsin
I'll give that a whirl. Thanks.
redline4
I'm huge in Japan
12:40 AM
Rosholt Wisconsin
Not every saw will have that. That washer came with the change of the carburetor mounting. You have to older version without this washer.
Thanks guys.
Having the parts lists is nice but I've noticed it sometimes isn't correct, especially dealing with older versions that have gone through a few design changes and parts supercessions.
redline4
I'm huge in Japan
12:40 AM
Rosholt Wisconsin
Not having a plasma cutter, I tried my version of Steve's baffle mod with what I had available.
I drilled the spot welds with a spot weld bit
Pried the sides up
Pried the front up and it promptly snapped off which was nice
Then with a grinder disc on my right angle die grinder I ground off the outlet side flap, and did a variation of what @Stump Shot mentioned, I bent the front down slightly and the flywheel side flap I left and kind of angled in that direction.
I doubt that tab will make any difference, but if something doesn't seem right once it's running, it's not as if it would be much effort to remove the muffler and remove that tab..
hacskaroly
2100 Fanclub Member
10:40 PM
Northern Idaho, Ehh
This is a fun thread. I just finished rebuilding an 066, previous owner used it and while it was still hot, decided to clean it with some ether. Fire ensued and by the time he got it out, most of the plastic and rubber had melted. On top of being melted, it was dirty like yours. I appreciate the pics you are showing. I could not figure out how to get the oil line out of the case, so i just cleaned around it, but it would have been easier to pop it out with a punch, will keep that in mind for next time. Currently working on an ugly 046 that someone abandoned at the dump. Very dirty, slight scoring on piston and cylinder and a broken rear handle, but having a great time working on it!
redline4
I'm huge in Japan
12:40 AM
Rosholt Wisconsin
Thanks.
I did an 046/ms460 thread a while back too.
Member
12:40 AM
