Bigmac
8:07 PM
You have some very nice saws there Bigmac. The 797 will pull a 50 no problem
and you will love the 101 saw. They are a blast to run.
Thanks Lee, I love them, they are impressive saws for sure, and considering there era, truly amazing!! I have run my 797 with 32” bar and it felt strong, like it needed a bigger sprocket or to be running a long bar, and I prefer the lever decomp over automatic. I think I have all the bugs worked out of my 101, I was chasing a bad condecer...would spark beautifully but only run for a second then die, after lots of parts swapping its now starting and running great, about ready to put it in wood!
Steve
Excellence!
10:07 PM
Did you build your 101 with the 125 intake and reeds or did you put a sloper intake in it? Really like your posts! Keep them coming!
Bigmac
8:07 PM
Thanks! Yes I used a 125 intake, nos reeds and manifold, still had to surface it to get the reeds to seat fully, I did port the manifold, I have a few ideas for preformance, I want to fill the manifold with epoxy and rework it, there is a huge dead spot the I think would ad in response and power(dirt bikes have highly developed reed cages) I think filling would really help. I would like to try a kart cage with custom manifold that still used the stock intake boot. I have done a mock up and I think it will work.(don’t want too cut up the air box) I don’t know if the reeds are a major restriction or the carb...0r both? I am assuming both, but I would like to see if there are gains in the reeds and manifold
Lee H
8:07 PM
cape cod ma.
Any time you put a 101 in a stock saw chassis you are detuning the 101.
The 101's came from the factory with a carb that has a 1-3/8 throttle bore.
A few on the saw sites have gone through the pain of making stock appearing
125's with the big carb. The stock 125 muffler doesn't help either.
This one I built over a year ago using the Tillotson HR race carb. It has a 1-3/8 bore.
It is done and is a real hoot to run. If you look in the Upstate NY gtg thread you will
see a video of it running.
hseII
Heef
11:07 PM
West Georgia
View attachment 122071 View attachment 122072
The Bugler
Bigmac
8:07 PM
Sweet saws Lee!! I NEED to build something similar! I have one more 101 saw in the build phase(stock style) all of the paint is done, just need a few little parts. I have two more kart motors that I would like to play with, I really like your 797/101 with the kart carb!
justoldsaws
From the land downunder
3:07 PM
Picked up this today, it's had a hard life.
I'm not sure of the model, what do you all think. Is it a CP125??
Thanks for any help
20180426_133129.jpg 20180426_133247.jpg 20180426_133219.jpg 20180426_133346.jpg Justin
Lee H
8:07 PM
cape cod ma.
Sp125 variant, Not a CP125. Someone must have swapped the filter cover.
Definitely a repaint and looks like the fuel tank has had some repair work.
Has the Walbro SDC fully adjustable carb which is nice. I would remove
the muffler and look at the piston before moving further. Nice saw but needs
a lot of TLC.
Bigmac
8:07 PM
Nice find! Looks like a cp125 with a sp125 engine, has the sp coil and muffler but the short starter cover with the and no throttle lock on the handle
justoldsaws
3:07 PM
Cheers for the response, my thoughts exactly on being a SP.
Yes in very poor condition, good thing it was very cheap.
Fuel tank has been resealed and poorly done I might add, muffler has been damaged/rusted out in the front and repaired with a lot of weld.
Piston has some scoring along the exhaust port side.
Bigmac
8:07 PM
Is it a chrome bore or steel?
Bigmac
8:07 PM
Cool!! That’s a major bonus in my book, you can bore it if needed!
11:07 PM
Now I'm not all that certain it is steel .My guess is grade 50 cast iron or nodular iron cast in the block as opposed to a sleeve .
justoldsaws
3:07 PM
Put my newly acquired 125 up against my 105 for comparison.
A few differences sighted20180427_140740.jpg 20180427_140805.jpg 20180427_140820.jpg 20180427_140902.jpg
Different decomp height
Different side cover and air filter cover
Different on/off and manual oiler button
Bigmac
8:07 PM
Your new saw is definitely a mixed bag, and that’s ok, just not completely original! There is a lot of parts that are interchangeable between models and that’s the beauty, you can create and keep thing going with a variety of options! Original is cool...so it custom...I love both!!
Bigmac
8:07 PM
