justoldsaws
From the land downunder
- 7:55 PM
- May 22, 2017
- Australia
No not yet, on Mike's site it says there only 1mm difference in the bore between 105 and 125.
I've seen vid clips where people had claimed to have a 101 in a 125 frame work .Quite frankly they didn't run as good as my two stock 125's . What ever oohs and aghs came from people who had never seen a good running 125 or a 101 for that matter .Any time you put a 101 in a stock saw chassis you are detuning the 101.
The 101's came from the factory with a carb that has a 1-3/8 throttle bore.
If it were steel my guess it would be type 4140 which is used for aircraft cylinders .The problem being two fold ,the thermal rate of expansion and the fact 4140 is much more difficult to finish than cast iron .FWIW the pistons rings for both the CP 125 and the SP 125 are the same which are tool steel .I'm not certain if those would work on hard steel like 4140 .Then the fact that cast iron has the ability to carry the oil film better than steel so it's more or less a guess on my part as to how well it might work .I agree Al, probably iron of some kind, I was speaking in general terms
Have you measured the bore?
Piston needs replacing for sure, hope the cylinder isn't scored as well.Great!! What are your plans for her?
Nice haul!Today's Mac haul, was being thrown out, a buddy saved it for me.
I'm seeing 125 partsNice haul!
