- 11:37 AM
- Nov 24, 2023
- Northern Idaho, Ehh
Nice looking saws, glad you got the issue resolved!Some photos for those who appreciate 1970's styling
That is a really nice looking saw!!NOS Double Eagle 80
Does anyone happen to have a Super 250 recoil assembly sitting around? I’d like to get one my my two operational.
I think I can help with that. I'm out tomorrow but I can look on Monday.
Gotcha - yeah I have what you need.Awesome! Here’s what I’ve got. One is the regular 250, the other is a Super. I assume I can use the cover from the 250 on the super 250. Just need the bolt on recoil part.
Even the cold is pretty low, did you check the piston to cylinder clearance? And ring end gap?I had some 82 cc cylinders sleeved a couple of years ago and put one saw (SP81) together to give them a try.
Cold compression seemed to be O.K.
But after running for a minute or two the compression dropped off significantly. I ran several trials and every time the same thing, run well for a bit then lose all compression and quit.
I took it apart today and there is nothing obvious amiss. I wanted to see if a different (sleeved) cylinder worked any better so I started on that project today.
We shall see...
Mark
