lehman live edge slab
Live Action
9:29 PM
Mn
This is it if Randy can use and it will work.
heimannm
9:29 PM
Dike, Iowa
The problem with using an early front tank saw for a 101 engine is the crankcase bottom (AKA stuffer) is built into the fuel tank and won't clear the counterweights on the crankshaft.
Later front tank models like the Super 250, 300, 380, 450, and 550 had a separate crankcase bottom piece. All of those models had some form of automatic pulse operated oil pump so you would have to make sure the crankcase bottom and the front tank would play nice together.
The 1-7X and 7XX models have the separate oil tank/bar mount that works with the different crankcase bottom pieces.
Putting a 91B into a MAC15 is a bit easier since they are both "non super" type engines. Problem there is the MAC15 intake is very restrictive.
Mark
edju1958
10:29 PM
Western N.Y.
Can someone tell me what plug is used in the PM800? I got the saw today & it has a CJ6Y in it,which I don't believe is the correct plug.If I'm not mistaken,the DE80 used a DJ6J,or a DJ6.
The saw definitely has no spark,so I'm gonna try to find a non-running 610 & "borrow" the ignition module from it.The saw has great compression & was only missing a couple screws on the recoil.
edju1958
10:29 PM
Western N.Y.
Well I didn't find a 610 that I could cannabalize the ignition module from,but I went through my parts tote & found a BN ignition module that I bought from maxthemacman a couple of yrs.ago & I instal;led that.I put a shot of fuel in the plug hole,installed a DJ6J plug in it & 2 pulls later it was running.I had to shut it off because the tank was empty & I didn't want it to lean out.It's a great running saw,but I can't get the manual oiler to work.Only a few drops of oil come out at the bar pad & I can hear it suicking air.I'll investigate the oiler tomorrow.It could just be a dirty screen.It's missing the outer bar plate & the bar adjuster assembly.
edju1958
10:29 PM
Western N.Y.
I need some help here in figuring out why the manual oiler won't work.I pulled the cover off the oil tank yesterday & the automatic pump was securely in place & the oil pick up seemed to be in good condition with a clear pick up screen.When I push the oiler button I get very little oil if any at the pad & it's sucking air from somewhere as I'll get air bubbles at the pad.
Live Action
9:29 PM
Mn
I wonder if the plunger seals for the manual oiler are flexing and letting air by
heimannm
9:29 PM
Dike, Iowa
Ed - I will presume we are still talking about the PM800?
There are 2 check valves in the oiler system, one is the disc under the manual pump and the other is a check ball (and spring) in the automatic oiler. If either of those are not functioning the oiler will not work.
To access the disc check valve in the manual oiler the tank has to come off, cover off the oil tank, and remove the two screws holding the manual oil pump down. One is tapped into the housing, the other has a nut (11/32") inside the tank. There were two different discs used and they have to work with the flange on the oil pick up hose. The thicker phenolic disc works with the thinner flange, the thinner aluminum disc work with the thicker flange.
Thin flange
Thick flange
To access the ball check valve in the automatic oiler you have to remove the automatic oil pump from the tank (should be one screw and the spring clip on a PM800). On the older pumps you could remove a screw from the top of the pump and take everything out. This is another version of a spring clip that attached to the top of the automatic pump to help press it firmly against the seal (gasket) at the mounting surface.
On the newer pumps there is no access to the ball and spring so you just have to shoot some brake or carburetor cleaner in the ports and the steel guide in the pump and hope it unsticks the ball.
Test the check valve by putting some oil in the inlet hole and working the piston manually. If everything is O.K. you will see the oil go down the inlet and back up the outlet. Inlet is on the left, outlet on the right. You can also test the check valve by applying pressure to the outlet side, is should hold 5-7 PSI, but just holding pressure will not tell you if the ball is stuck. If you apply pressure to the inlet side it will push the piston out.
Mark
9:29 PM
Thin flange
Thick flange
Mark
You are a absolute wealth of knowledge my friend.
edju1958
10:29 PM
Western N.Y.
Thanks Mark! I have a couple of NOS pumps on hand that I secured from Bob J.before he closed up shop.I'll just try a new pump & see if that solves the problem.I can't really see the manual oiler disc going bad,although stranger things have happened..
Max the Mac Man
10:29 PM
Middlebrook Virginia
Many of you by now know of my history/journey with McCulloch saws. Over the years I have met many great folks in the saw world. One of those is Mark Heimann. After a few years on phone conversations, emails and so forth I made my first trip out to see Mark in the late summer of 2023. It was a wonderful visit. Seeing the museum and talking to Mark about saws in person is an experience any McCulloch enthusiast should have. Before I headed east for home, I noticed a DE 80 on his sell shelf. The crankcase was gray, and I asked Mark if it was what I thought, he confirmed it. A PM 8200 block under a DE80 tank. I told Mark I had all the parts to take the saw and make the PM 8200 engine back into an original full-grown PM 8200, as well as make the DE 80 parts back into a full-grown DE 80. A deal was struck. The saw came to live in Virginia. I sat in in a shelf and there it sat. I never dug out my used spare parts to piece it back into a PM 8200. Fast forward to last fall on eBay I saw a very clean PM 8200 for sale with a bad cylinder. She was cosmetically prettier than the sum of my used parts, so I bought her, and she came to Virginia to sit on a shelf (y’all see a pattern here? lol). Last Saturday I tore the roached PM 8200 apart. It was BAD inside. The worst 82cc I have seen yet. Massive air leak from the intake boot, she got HOT and ate herself alive. Sunday Alan came over to help me with some stuff and we found time to take the DE80/PM 8200 from Mark apart and place the engine from it into the other PM 8200. Its back together and alive as a fully original PM 8200 now. The DE 80 parts will be used to transform a very ugly but very strong running PM 805 into a full-grown DE 80. Maybe it will not take another two years to get to that one lol. Only 14 more saws left to fix if I don’t add more!
Max the Mac Man
10:29 PM
Thin flange
Thick flange
Mark
Good Info Mark!
9:29 PM
View attachment 455535View attachment 455536View attachment 455537View attachment 455538View attachment 455539
Well howdy Max.
That might be the worst piston I've ever seen.
Angore
10:29 PM
Western NY
And I just recently picked up one of these .
I already have several tools that use the same batteries and it's small enough that I can carry it on my wheeler .
i bought a padded bag that holds extra oil , 2nd battery / charger & tools . I havent used it yet and I know it's cheap & small but rather than toting one of the big saws around , this should work nicely .
