Rallyeguy
8:58 PM
Wisconsin
I am not happy that I don't have a McCulloch yet to match those.
You and I both my friend :) not sure if I ever will or not but at least I can make stuff for the guys that do.
Cool idea on the formed plate. let me know if you ever get that to work for you....
Brian
jacob j.
Only the weird
6:58 PM
Coastal Oregon
A bad ass gear drive would be so cool.
It's not hard to do and I think you can use the existing motor mounts. You might need to set-up some 10-28 nuts in the 101 crankcase
just under the intake manifold area. @heimannm would be able to get you the dirty details on it. You would likely need to trench a hole
for the manual oiler rod.
8:58 PM
Another rabbit hole !!!!
jacob j.
Only the weird
6:58 PM
Coastal Oregon
I have another 101 to build for a friend. This one will be a race saw.....so I need help. Mark tells be that I need to be thinking about a custom intake.....and a big HL.
There's some options for intakes. Mac makes a sloper that can mount one of the big BDC carbs, a WB (like on one of @Bigmac 's saws) or a large Mikuni. The Reed 458 sloper will mount a Tilly HL, and there's some good options there. Nathan @Bigmac has some custom low-profile slopers that will work with several carburetors. There's also some straight-shot type intakes. I have quite a few different things I can post pictures of.
8:58 PM
I've got good help in the shop now. We do a lot of saws....so I can sorta get back into some stuff I find interesting now. Im looking forward to seeing what can be done with a McCullough.
Bigmac
6:58 PM
If you’re wanting to do a race, saw, my manifold is more meant for a full airbox style, I would probably use at least a V6 rreed cage and personally would run a jet ski carburetor. The McCulloch port layout is excellent, adding some sub exhaust ports is a good idea if you’re looking for max power, also if you’re looking for max power, I would definitely run a billet rod. Kinda just depends how crazy you’re gonna wanna go! If you’re planning on running a pipe on it or not. If you’re looking for stock appearing or not all of those things, kinda change the build.
8:58 PM
That’s cool.
8:58 PM
I have a race saw to do for a friend, and a stock appearing saw for myself. His will be piped.
