cinci5
10:33 PM
Hamburg, NY
I've bought around 14 125C projects over the years and only one of them had a good cylinder in it.
The plating that Mac used for those just didn't stand up as well as more modern saw cylinders. It was
a great design and the "C" cylinders make good runners though.
If you have a125C housing I'm in need as mine broke off just above the muffler.
the 28inch mac man
10:33 PM
Southern NH
HI, I have a question for all yall out there. I have a mac bar that is 37.5 inch or something like that. Anyway mcculloch called it a 40 inch bar. It has super pro on it and is a roller nose. Do any of you know what the drive link count on this bar would be? My 440 that it is going on has a 404 drum on it. It shore is a sweet looking bar!
heimannm
9:33 PM
Dike, Iowa
Yes, that is a PM55 with the black fuel tank. I put a new piston and cylinder on that one and it is also a ripper but it cannot hang with the 7-10.
The full wrap bars I had made are wide enough to accommodate the chain brake covers but the clutch covers must be modified to clear the wrap bar.
PM700, long clutch cover only requires a slight modification. In reality you can add the clearance needed with a file and it can be much less severe that what's shown below.
The short clutch covers require more substantial modification.
Mark
