- 4:13 PM
- Jan 28, 2016
- Dike, Iowa
1-75 is tpgether and runs but has a few minor issues. Some will need more attention ans some, like the very soft "shock mounts" or the front handle will hopefully hold up throgh the PNW GTG then on the shelf for that saw.
That large felt washer over the crankshaft is supposed to be oiled and help lubricate the clutch drum bushing/bearing. The muffler shield was pretty badly beat up and cracked, some low temp brazing rod and the yellow "Mapp" cylinder for my propane torch took care of repairs.
Part of the sawdust shield behind the starter/clutch cover is missing, but I think for a few cookies at the GTG and for sitting on the shelf it should be O.K.
I still have a good supply of the round grills for the flywheel covers...
I will take the carburetor off again today and swap out the metering set with a stainless steel plate for a set with an aluminum plate just for the sake of science.
Mark
Mark
