- 2:32 PM
- Jan 28, 2016
- Dike, Iowa
I’ll take that Mcculloch jacket if it’s a XL . LolI actually have a corner of my display area dedicated to the 33/35/39 model saws. You can't see it in this photo but there is a Super 33 with the brush cutter attachment handing from the ceiling. The 35A was added after this photo was taken.
Mark
I beg to differ Steve.A plug that's too hot can potentially burn a hole in the piston.A plug that's too cold won't get nor keep the engine running.In essence,we need the Goldilocks plug.One heat range up or down won't matter too much,but beyond that one could be flirting with disaster.The heat range is the least of your worries and a moot point sense the plug dynamics are no longer any where close to what it left the factory as. Plus, it's a chainsaw, Not a formula 1 car. Lol!
An 18mm plug won’t work, at least based off of what you’ve said so far. You mentioned the inserts you got that are the same as the ones suggested from McMaster-Carr just fall through the hole. The inserts from McMaster require either a 3/4 or 18mm tap to install which is the same or bigger than the 18mm plug. If the insert falls through so will the 18mm spark plug. Now if you were mistaken and didn’t have the same insert, then you could go with that insert and still stick with an OEM plug with no worries of melting a hole in your pistonI beg to differ Steve.A plug that's too hot can potentially burn a hole in the piston.A plug that's too cold won't get nor keep the engine running.In essence,we need the Goldilocks plug.One heat range up or down won't matter too much,but beyond that one could be flirting with disaster.
that’s awesome! I’d definitely like to do another 33 with a different attachment.I actually have a corner of my display area dedicated to the 33/35/39 model saws. You can't see it in this photo but there is a Super 33 with the brush cutter attachment handing from the ceiling. The 35A was added after this photo was taken.
Mark
I didn't say I had the same inserts as those on McMaster-Carr,I said I had the same inserts as those suggested at Advance Auto - the Save-A-Thread Inserts.An 18mm plug won’t work, at least based off of what you’ve said so far. You mentioned the inserts you got that are the same as the ones suggested from McMaster-Carr just fall through the hole. The inserts from McMaster require either a 3/4 or 18mm tap to install which is the same or bigger than the 18mm plug. If the insert falls through so will the 18mm spark plug. Now if you were mistaken and didn’t have the same insert, then you could go with that insert and still stick with an OEM plug with no worries of melting a hole in your piston
That 35 is incredible! I was actually worried about the “special touches” I realize purists can take offense to such things, I plan on doing many more and will take liberties on those as well. I’ve been running saws for 20+ years.. climbing, boom truck all of it, just not “professionally “.and I make my living turning a wrench. but not on saws, i’m a rank amateur in this genre and not ashamed to admit it! Im looking forward to learning.The Super 33 is a good looking saw to begin with, you have done a really nice job of applying the special touch here and there.
You are correct, 1/2" pitch Pin Tail chain is very hard to find, in fact most any 1/2" pitch chain is becoming quite scarce.
I have a 35A that my brother picked up NIB, nice display unit.
Mark
Awoke with an epiphany. Can you guess what it was?I just finished rebuilding and beautifying my best running SP125. Had to prime her down the carb and hold the throttle wide open to get her started but when she fired she ran like a scalded cat. Could not get her to idle at all, though. After hours of troubleshooting, rebuilding carbs. swapping carbs, plugs, fuel lines and everything else I could think of I gave up. After lunch decided to take a nap on a cold rainy day.
View attachment 362311 Awoke with an epiphany. Can you guess what it was?
Pinched line ? Hard to tellI just finished rebuilding and beautifying my best running SP125. Had to prime her down the carb and hold the throttle wide open to get her started but when she fired she ran like a scalded cat. Could not get her to idle at all, though. After hours of troubleshooting, rebuilding carbs. swapping carbs, plugs, fuel lines and everything else I could think of I gave up. After lunch decided to take a nap on a cold rainy day.
I can't, but then I'm blind as a bat also.Tough place to take a photo, especially for someone who already struggles with cell phones and computers. Can you see what the throttle rod is resting against in the photo?
