farminkarman
I like the red & black ones
- 1:01 PM
- Aug 17, 2020
- Neenah Wisconsin
Yes it is...will be spinning it very slow...the fixture has quite a bit of mass off-center opposite the jug, so it isn't too bad.That a lot of swing...
For sure! I was hoping to make something that would allow me to setup a jug fairly quick to cut the bearing pockets….still need to try cutting oneThat lathe set up amuses me ,looks like something I would do .Nothing is impossible but at times it takes longer to build the holding fixture than it does to make the cuts .
Just updating everyone...as you probably know my younger brother Ed passed away on 7 August and my older brother Ray has been battling cancer for the past year and a half. Last night Ray lost the battle. Things will be different moving forward.
Grantsburg, WI 2010
Mark
Hi guys. I purchased a couple parts on Ebay. Two intakes that were listed for SP105's. Figured they were reasonable so least I could do is pass them along if they won't work for 125. I haven't been in the game much for my 125's due to life and moving. Due to my saws/parts/ipls being in storage from moving can anyone tell me if this part number is the same from 105 to 125? I can not find an ipl online. Thanks everyone.
They're the same...
I am looking into some reproduction piston rings for certain part numbers that are no longer available. Initially I am considering:
87854 - standard thin rings for the 82 cc 10 Series saws (SP80/81/81E, PM850/800/805, DE80, PM8200)
89732 - standard thin rings for the 70 cc 10 Series saws that use the 85239 piston (some 7-10, PM700, etc.)
62814 - standard thick rings for the 54 cc 10 Series models
My initial reseach has turned up a possible supplier (RJ Machine in New Mexico) but I would have to sell the rings at $30+ per set plus shipping to make it work.
I have checked with DLA (Greece) and they don't have anything available.
I have also gone through a few other AM sources and have not found anything close enough to make due for these saws.
My real question is, at $30+ per set would I ever be able to sell these rings?
TIA for your consideration.
Mark
