edju1958
- 2:51 PM
- May 23, 2018
- Western N.Y.
I went out cutting yesterday for the 1st time this season.A big old cherry tree had fallen into my farmer neighbor's field & took out a small hard maple with it.I took 5 saws with me,they were a Mac 5-10,one of my recently repaired 610s,my Super 10-10,another 10-10,& a Homelite XL-113.Every damn saw I took out had a problem.The Super 10-10 decided that the push button for the manual oiler wasn't going to be pushed in,it worked at first & then it "locked up".I then got the XL-113 out & it fired right up,but the idle was set way too high,so I shut it down.The other 10-10 has a carb issue in that it wants to run way too rich.The 610 has a damn Zama carb on it & it won't throttle up the way it's supposed to.The 5-10 won't start unless I hold the trigger on while pulling it over,other than that it ran flawlessly till I noticed the screws holding the spike on decided to loosen.I loaded up what I managed to cut & came home for a late lunch at around 3:00.
I took the spike off the 5-10,then made some adjustments on the Homie & the 610.I grabbed another 10-10 & went back to the site.It was deja vu all over again.The XL-113 made one cut,then it developed an ignition problem,could be a bad plug,or a condenser breaking down.I'll investigate it later.The 10-10 started up & ran great,but as soon as I put it to the wood the chain stopped.I think it's either a clutch problem,or the chain may not be on the rim.I like rim drives,but on a Mac they're a PITA to get on the rim.Next up was the 610.All the carb adjustments in the world didn't make a difference with the bleepin' Zama carb.There's only one good place for a Zama carb & that's in the nearest dumpster IMO.
The hero of the day was the 5-10.I had a problem with the saw right after I got it.I had the carb off for a rebuild & I had cleaned the points & was re-gapping them when it locked up & I couldn't turn the crank to get the points to break.I thought I hadf dropped a small washer down the carb throat,but as time went on that wasn't the problem.I sent the saw to a friend of mine & he tore it down.He texted me with the diagnosis - the piston was scored & he happened to have a new piston on hand that he'd sell to me,but it had no rings.Fortunately I had the foresight to buy a new set of rings from Bob J.& sent them with the saw.The reason the saw was locked up was because one of the rings was broken.The ring broke when I was turning the engine over by hand.What are the chances of that happening?If the ring had broke when the engine was running it'd probably ruined the cylinderr.I got lucky there.My friend put the saw back together & had it running like a Swiss watch & sent it back to me.I put a 22 in.Partner bar on it that I modified & it pulls that buried in hardwood like nobody's business.
Today it's raining here,thank goodness,Lol.I need a couple days off to recuperate & repair saws.
